Just got my 2003 rs, god what a car !!! But..... Iam getting condensation on screen,( it has solar roof) have checked floor mats (all dry) have checked blocked drain off windscreen (all good ) any ideas ?
Cheers Mark.
Air con/ solar roof.??
RE: Air con/ solar roof.??
Yes, it's a common fault. There is a fix for it as per a tech bulletin. I'll PM you it if I can.
HTH
Grant
HTH
Grant
is it anything to do with servicing the a/c ? mine mists a little after i swtitch back to normal air , i think its residual moisture which soon goes with the blowers on
phil
phil
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
I should say big thanks to Grant who forwarded me the details already - my 03 RS6 is affected. I should check the windscreen drain holes though.
I notice the problem on particularly wet days, after a relatively short journey ... I'm confident that it's the solar roof fix I need, however, my local Audi dealership quoted just under 500 pounds, so it's dropped a bit down the list of things to do - tyres and brakes first. I did have the aircon serviced and deodorised, which sorted out the whiffy air, and helps clear the condensation if it turns up!!
N
N
Cornishmoocher
- Top Gear
Watch the dodgy buggers in the stealers, they told me that my AC was smelling and that it need re-gassing. I asked them what re gassing was going to do, they fed me some bollox, at which point i told them i was an AC engineer, and miraculously they just deoderised it for free.......
It's all Bollox.
