Air con/ solar roof.??
g338iry
Post by g338iry » Sun Aug 10, 2008 6:34 am
Just got my 2003 rs, god what a car !!! But..... Iam getting condensation on screen,( it has solar roof) have checked floor mats (all dry) have checked blocked drain off windscreen (all good ) any ideas ?
Cheers Mark.
GardinerG
RE: Air con/ solar roof.??
Post by GardinerG » Sun Aug 10, 2008 12:55 pm
Yes, it's a common fault. There is a fix for it as per a tech bulletin. I'll PM you it if I can.
HTH
Grant
philroach
Post by philroach » Sun Aug 10, 2008 8:40 pm
is it anything to do with servicing the a/c ? mine mists a little after i swtitch back to normal air , i think its residual moisture which soon goes with the blowers on
phil
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Balchy
Post by Balchy » Mon Aug 11, 2008 10:49 am
I should say big thanks to Grant who forwarded me the details already - my 03 RS6 is affected. I should check the windscreen drain holes though.
I notice the problem on particularly wet days, after a relatively short journey ... I'm confident that it's the solar roof fix I need, however, my local Audi dealership quoted just under 500 pounds, so it's dropped a bit down the list of things to do - tyres and brakes first. I did have the aircon serviced and deodorised, which sorted out the whiffy air, and helps clear the condensation if it turns up!!
N
GardinerG
Post by GardinerG » Mon Aug 11, 2008 1:11 pm
The whiffy smell for me was sorted out by a can of household deodoriser and a new pollen filter. Not come back since. :thumbs:
Cornishmoocher
Post by Cornishmoocher » Mon Aug 11, 2008 3:15 pm
Watch the dodgy buggers in the stealers, they told me that my AC was smelling and that it need re-gassing. I asked them what re gassing was going to do, they fed me some bollox, at which point i told them i was an AC engineer, and miraculously they just deoderised it for free.......
It's all Bollox.
Users browsing this forum: Bing [Bot] and 111 guests
