tyres should be changed occassionally front to back to create even wear , as it says in the owners manualPetrolDave wrote:Don't.pippyrips wrote:What’s the general rule of thumb with swapping tyres round ?
4 Tires = £873
wait for it......
RS4 Avant - Daytona Grey SOLD
Focus ST wth a tweak
03 911 (996) turbo SOLD
06 Wrx impreza SOLD
06 Wrx impreza SOLD
- PetrolDave
I'd have agreed about Quattro tyre wear until the B7 RS4. Both sets i've been through have shown around 25% more wear on the fronts than the rears & i check the pressures weekly.PetrolDave wrote:With all the quattro Audis I've had (S3, 2 x B6 S4, B7 RS4) the difference in wear rate between front and rear is so minimal that there's no benefit swapping front and rear.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
similar results with my fronts compared to the rears alsoW8PMC wrote:I'd have agreed about Quattro tyre wear until the B7 RS4. Both sets i've been through have shown around 25% more wear on the fronts than the rears & i check the pressures weekly.PetrolDave wrote:With all the quattro Audis I've had (S3, 2 x B6 S4, B7 RS4) the difference in wear rate between front and rear is so minimal that there's no benefit swapping front and rear.
Yep, I regularly keep an eye on the pressures but the fronts are definitely wearing quicker than the rears at present, (with the front nearside showing the most which I’m putting down to roundabouts as mentioned previously.)
I had the alignment checked when they went on so at least I know its pointing straight!
Marcus-RS4
- PetrolDave
I was filled with 36 all round as this was advised upon fitting of the F1's, however folk on here said 38 so i upped them & they feel great. Defo better then the OEM P Zeros & so far appear better then the PS2's i had on the RS6 & M5. Plenty of grip & the road noise/ride is much improved.
Paul
Another satisfied convertee to Goodyear 275/30's Cost all in was £720, £680 for four tyres from mytyres.co.uk and £40 for fitting and disposal from local fitter.
Turn in is much better as is road noise and wet handling over Conti SC3's. Running on 38 all round but I don't believe after 400 miles thay are fully scrubbed yet and giving their fuill potential..
Marcus-RS4
Users browsing this forum: Zyox and 258 guests
