FMIC Install ?
FMIC Install ?
Just got my piping kit for my FMIC. Gonna give it a go fitting it. any pointers ? any one done it?
Wide Body S4
quattronutter
RE: FMIC Install ?
make sure you have plenty of cutting wheels for your grinder
RE: FMIC Install ?
Where didi you get the pipe work from ?? g
Unit 20
0151 3366888
0151 3366888
Take out the grills. This is the easy bit. I took the headlights out too, they look expensive to replace.
Take off the bumper. This is bit of a leap of faith as you have to rip it from the plastic "teeth" in front of each wheel arch. There are two long bolts reached from inside the grill apertures and a couple of screws in the wheel arch.
Remove the AC fan, the bracket, the shrouds and the iddy biddy side mount intercoolers.
I used a 9" grinder and a 3" grinder to cut the insides of the bumper to fit.
Fix the intercooler in place. Add the pipework.
Fit the bumper back on. Bumper off. Take the pipework off again, move the intercooler, curse the pipework, refit the intercooler, remove it, curse it, hit it, refit it and the bumper.
You do this several times, each time moving the intercooler or shaving a bit more bumper off. Stop when it gets dark.
FMIC DONE.
FMIC DONE.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
quattronutter
should of been one more metal and a 45 degree silicone hose. I had to cut some of the metal pipes and use silicone pipes to make up the pipes to fit, they are not like mrc ones. also had to get metal beeds welded on when I cut the pipes or it just pop off when boosting
1.9TDI A6 are sh*t wrong forum
Musty, those are the new-style pipes.
CXRacing copied them from JHMotorsport ones.
This kit should fit like a charm.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
Users browsing this forum: Google [Bot] and 46 guests
