RS4 B5 Clutch Change - anyone done it?
- leyshonbrent
If so can you give me some tips please - particularly interested on how you dropped the box off - engine/Box out or does the box come off easily. How did you manouvere it - cradle? Did you move engine on mountings? I assume its rather heavy with the transfer box fitted.
Any tips would be useful - I will photograph a step by step when I do it for the site .
Brent
Brent
Misano Red B5 RS4 - For Best
Battered A4 1.9 TDI Avant - my weekend van and Station Wagon
Mk1 Escort Mexico - Childhood Sweetheart
For Family - VW Touran 2.0 TDi Sport
RE: RS4 B5 Clutch Change - anyone done it?
quickest way is engine out, first time I took the engine out on v6 biturb it took 4 times as long because the bolts on the gearbox are so difficult to get to, not to mention how annoying reaching for sensors etc is
- leyshonbrent
mmm - thanks thought that might be he answer .....
How did you do it after the first time - are the gearbox bolts you metioned just hard to get to or hard to get to if you leave the engine in? Any recommended lessons and how much long does it take do you recon?
Thanks again
Brent
Thanks again
Brent
I have done it always by removing the engine with the gearbox.
Fastest time has been around 11 hours with S4.
- leyshonbrent
OK - engine and box coming out. Eleven hours sounds fast! Ahem - I'm allowing 4 days...
Wish me luck!
Thanks guys for the tips
Brent
Wish me luck!
Brent
Don't take the engine out !!!! It's a piece of cake. Box is not that bad at all.
Unit 20
0151 3366888
0151 3366888
- leyshonbrent
Some good news!!
Any tips would be appreciated!!
Brent
Brent
- mikeyquattro
- Top Gear
Dialynx took the box out when my clutch was done.....
Tomorrow is another day
- leyshonbrent
Moore good news - Thanks
I am going to try the box out option - have ordered the relevant Audi Transmission manual from erWin. Will report back.
Keep the tips coming though please
I did my S2 clutch (g/box out method, was too scottish to lose a/c gas!) a couple of years ago & by f**k! that box is heavy!
If I remember rightly the hardest thing was getting the box past the downpipes. Could have removed them but I hate exhausts!
Took 2 of us about 6 hours. Probably easier than RS4 tho despite the procon ten.
Top tip: make sure you have a hydraulic cradle!
I've just done the clutch on an S4. My procedure was as follows:
I unbolted the subframe at the rear, catalysts-to-exhaust, prop and driveshafts.
The rear dropped low enough to get to ALL the bellhousing bolts, from underneath (I use a lift).
I undid the crank sensor, and hung it out of the way, unbolted the selector rod and stabiliser.
I removed the single bolt holding the clutch slave cylinder in place, and cable tied it to one side.
Lastly, I unbolted the 2 tranny through bolts from the subframe, and removed both brackets themselves from the tranny.
At this point, I unbolted all the bellhousing bolts, using an air gun and long extension for the uppermost ones, leaving the top most centre one till last, supporting the tranny with a transmission stand.
I then rocked the tranny free from the engine. It helps if you have an assistant to help pull the catalyst on the driver's side towards the outside of the car - not too hard though, else you'll damage the flexi section. If you have no assistance, then you can use cable ties / rope to tie both catalysts away from the tunnel, and pull the box off.
From start to finish, it took me 6.5 hours.
