RS4 B5 Clutch Change - anyone done it?
2.7 V6 30v biturbo - 380 bhp
leyshonbrent
Post by leyshonbrent » Tue May 27, 2008 4:22 pm
If so can you give me some tips please - particularly interested on how you dropped the box off - engine/Box out or does the box come off easily. How did you manouvere it - cradle? Did you move engine on mountings? I assume its rather heavy with the transfer box fitted.
Any tips would be useful - I will photograph a step by step when I do it for the site .
Brent
Misano Red B5 RS4 - For Best
Battered A4 1.9 TDI Avant - my weekend van and Station Wagon
Mk1 Escort Mexico - Childhood Sweetheart
For Family - VW Touran 2.0 TDi Sport
dummi
RE: RS4 B5 Clutch Change - anyone done it?
Post by dummi » Tue May 27, 2008 4:34 pm
quickest way is engine out, first time I took the engine out on v6 biturb it took 4 times as long because the bolts on the gearbox are so difficult to get to, not to mention how annoying reaching for sensors etc is
leyshonbrent
Post by leyshonbrent » Tue May 27, 2008 9:42 pm
mmm - thanks thought that might be he answer .....:-(
How did you do it after the first time - are the gearbox bolts you metioned just hard to get to or hard to get to if you leave the engine in? Any recommended lessons and how much long does it take do you recon?
Thanks again
Brent
okkim
Post by okkim » Thu May 29, 2008 8:31 pm
I have done it always by removing the engine with the gearbox.
Fastest time has been around 11 hours with S4.
leyshonbrent
Post by leyshonbrent » Thu May 29, 2008 9:18 pm
OK - engine and box coming out. Eleven hours sounds fast! Ahem - I'm allowing 4 days...
Wish me luck!
Thanks guys for the tips
Brent
grizz
Post by grizz » Thu May 29, 2008 9:38 pm
Don't take the engine out !!!! It's a piece of cake. Box is not that bad at all.
Unit 20
0151 3366888
leyshonbrent
Post by leyshonbrent » Thu May 29, 2008 10:19 pm
Some good news!!
Any tips would be appreciated!!
Brent
mikeyquattro
Post by mikeyquattro » Thu May 29, 2008 10:51 pm
Dialynx took the box out when my clutch was done.....
Tomorrow is another day
DerekS
Post by DerekS » Fri May 30, 2008 9:41 am
Do not remove the engine.
Gearbox out and takes about 6-8hrs max.
Hardest part is the gearbox support arms.
leyshonbrent
Post by leyshonbrent » Fri May 30, 2008 4:35 pm
Moore good news - Thanks
I am going to try the box out option - have ordered the relevant Audi Transmission manual from erWin. Will report back.
Keep the tips coming though please
S4
Post by S4 » Fri May 30, 2008 9:37 pm
yes get an exchange clutch from the dealer, the price is good.
Darren
Soupie69uk
Post by Soupie69uk » Fri May 30, 2008 11:10 pm
I helped do it on my A4 and I am sure the RS4 one is not that differen.
Some of the bolts were fiddly but the DTS comes in handy for supporting the box once it was all undone.
Mating the box back up took a while also as it did not want to go back together straight at first.
imolas4uk
Post by imolas4uk » Sat May 31, 2008 11:22 pm
take the snub mount off and raise the front of the enginr this will help you get the bolts at the top of the bell housing
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
missmouse
Post by missmouse » Mon Jul 06, 2009 9:17 pm
I did my S2 clutch (g/box out method, was too scottish to lose a/c gas!) a couple of years ago & by f**k! that box is heavy!
If I remember rightly the hardest thing was getting the box past the downpipes. Could have removed them but I hate exhausts!
Took 2 of us about 6 hours. Probably easier than RS4 tho despite the procon ten.
Top tip: make sure you have a hydraulic cradle!
Siena
Post by Siena » Sun Jul 19, 2009 5:24 pm
I've just done the clutch on an S4. My procedure was as follows:
I unbolted the subframe at the rear, catalysts-to-exhaust, prop and driveshafts.
The rear dropped low enough to get to ALL the bellhousing bolts, from underneath (I use a lift).
I undid the crank sensor, and hung it out of the way, unbolted the selector rod and stabiliser.
I removed the single bolt holding the clutch slave cylinder in place, and cable tied it to one side.
Lastly, I unbolted the 2 tranny through bolts from the subframe, and removed both brackets themselves from the tranny.
At this point, I unbolted all the bellhousing bolts, using an air gun and long extension for the uppermost ones, leaving the top most centre one till last, supporting the tranny with a transmission stand.
I then rocked the tranny free from the engine. It helps if you have an assistant to help pull the catalyst on the driver's side towards the outside of the car - not too hard though, else you'll damage the flexi section. If you have no assistance, then you can use cable ties / rope to tie both catalysts away from the tunnel, and pull the box off.
From start to finish, it took me 6.5 hours.
