Bosch fuel pump part number
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 10:33 am
Any one know the Bosch fuel pump part number.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
JonnyX
RE: Bosch fuel pump part number
Post by JonnyX » Wed Feb 06, 2008 11:06 am
058 0254 044
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 11:21 am
thats good. same unit as my mates are using in the high powered cosworths.
MING BLUE AUDI S4
Car is on Lock down
JonnyX
Post by JonnyX » Wed Feb 06, 2008 1:18 pm
Mine was 90 quid new from ebay.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 1:25 pm
Cool
MING BLUE AUDI S4
Car is on Lock down
Keihin
Post by Keihin » Fri Feb 08, 2008 7:32 pm
Is this S4 or RS4?
BRETTCOLLINS
Post by BRETTCOLLINS » Sat Feb 09, 2008 12:52 am
it can be used in both, it is an after market item
MING BLUE AUDI S4
Car is on Lock down
Keihin
Post by Keihin » Sun Feb 10, 2008 7:49 pm
Ok, so how does it compare to the stock ones? I believe that the stock S4 pump does not flow enough when upgrading with K04s. How "far" does this one keep up?
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Apr 21, 2008 1:59 pm
Is this the pump needed
Bosch 0 580 254 044 Inline Fuel Pump
Bosch 044 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump.
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
Fuel Pump Connections:
Inlet: M18 x 1.5
Outlet: M12 x 1.5
Electrical: Positive M6 / Negative M5
MING BLUE AUDI S4
Car is on Lock down
dummi
Post by dummi » Mon Apr 21, 2008 2:34 pm
that is the one most people use
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Apr 21, 2008 2:35 pm
many thanks
MING BLUE AUDI S4
Car is on Lock down
GHH
Re: RE: Bosch fuel pump part number
Post by GHH » Tue Apr 22, 2008 10:54 am
BRETTCOLLINS wrote:Is this the pump needed
isnt there also an intank version? or have i got it mixed up.
'00 Nogaro S4 Avant
'88 Oak Green Mk2 Golf GTI
BRETTCOLLINS
RE: Re: RE: Bosch fuel pump part number
Post by BRETTCOLLINS » Tue Apr 22, 2008 11:07 am
thats the 040 not the 044
MING BLUE AUDI S4
Car is on Lock down
JonnyX
Post by JonnyX » Tue Apr 22, 2008 3:23 pm
My 044 is mounted in-tank. I used the V8 Audi 80 strainer and basket.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
mattsimis
Post by mattsimis » Tue Jul 22, 2008 10:18 am
Sorry for the bump, but could you clarify if its ok to mount a Walbro 255lph inline pump intank in place of the stock S4 pump?
V10 5.0 Phaeton now and 2.7T Allroad
Users browsing this forum: No registered users and 233 guests
