Bosch fuel pump part number
- 5th Gear
Any one know the Bosch fuel pump part number.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
RE: Bosch fuel pump part number
058 0254 044
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- 5th Gear
thats good. same unit as my mates are using in the high powered cosworths.
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Mine was 90 quid new from ebay.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- 5th Gear
Cool
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Is this S4 or RS4?
- 5th Gear
it can be used in both, it is an after market item
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Ok, so how does it compare to the stock ones? I believe that the stock S4 pump does not flow enough when upgrading with K04s. How "far" does this one keep up?
- 5th Gear
Is this the pump needed
Bosch 0 580 254 044 Inline Fuel Pump
Bosch 044 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump.
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
Fuel Pump Connections:
Inlet: M18 x 1.5
Outlet: M12 x 1.5
Electrical: Positive M6 / Negative M5
Inlet: M18 x 1.5
Outlet: M12 x 1.5
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
that is the one most people use
- 5th Gear
many thanks
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Re: RE: Bosch fuel pump part number
isnt there also an intank version? or have i got it mixed up.BRETTCOLLINS wrote:Is this the pump needed
'00 Nogaro S4 Avant
'88 Oak Green Mk2 Golf GTI
- 5th Gear
RE: Re: RE: Bosch fuel pump part number
thats the 040 not the 044
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
My 044 is mounted in-tank. I used the V8 Audi 80 strainer and basket.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Sorry for the bump, but could you clarify if its ok to mount a Walbro 255lph inline pump intank in place of the stock S4 pump?
V10 5.0 Phaeton now and 2.7T Allroad
