Resetting Service Intervels
- 5th Gear
RE: Resetting Service Intervels
Go into instruments, adaption, group 2, the value shown will be 1, enter 0 save etc sorted.
- Virdee Autos
- Trader (Expired)
You can do it from the instrument cluster.....
Virdee Autos ~ 07950-526592
- 5th Gear
I lied, that was for Golfs Passats etc
As before but
The displayed values
01= oil serv due
10= insp due
11 oil and insp due
New values to enter
00= reset oil and insp
01= reset oil
10= reset insp
As before but
01= oil serv due
10= insp due
11 oil and insp due
New values to enter
01= reset oil
10= reset insp
Moved to VAG-COM forum
On the dashboard...
Ignition off
Hold in the spanner button on dashboard
Turn key to ignition on (not start) while still holding the button
Finally press and hold the trip reset (0.0) button and the service interval should clear in about 5 secs
I can't remember whether you still need to be holding the spanner button while doing the last part, but one or other will work!
Ignition off
2007 Daytona RS4 Avant
- PetrolDave
All those answers only work if you want to reset to fixed interval servicing.
If you have an Audi look here http://www.ross-tech.com/vag-com/cars/audi_sri.html
If you have a VW look here http://www.ross-tech.com/vag-com/cars/vw_sri.html
Alternative (for those using "current" versions of the software): Applications > SRI Reset
Sebastian @ Ross-Tech.com
Wow Sebastian - slick option. Thanks for the update (and another reason why we should use and support Ross-Tech rather then the fleabay leads)
