Resetting Service Intervels
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
h8cak
Post by h8cak » Tue Apr 15, 2008 7:44 pm
Any one know how to do this using vag com?
Wide Body S4
philipwalker
RE: Resetting Service Intervels
Post by philipwalker » Tue Apr 15, 2008 8:37 pm
Go into instruments, adaption, group 2, the value shown will be 1, enter 0 save etc sorted.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Apr 15, 2008 8:37 pm
You can do it from the instrument cluster.....
Virdee Autos ~ 07950-526592
philipwalker
Post by philipwalker » Tue Apr 15, 2008 8:45 pm
I lied, that was for Golfs Passats etc
As before but
The displayed values
01= oil serv due
10= insp due
11 oil and insp due
New values to enter
00= reset oil and insp
01= reset oil
10= reset insp
PW Motorsport
01437 563929
DavidT
Post by DavidT » Wed Apr 16, 2008 9:44 am
Moved to VAG-COM forum :)
Dom81
Post by Dom81 » Wed Apr 16, 2008 10:09 am
On the dashboard...
Ignition off
Hold in the spanner button on dashboard
Turn key to ignition on (not start) while still holding the button
Finally press and hold the trip reset (0.0) button and the service interval should clear in about 5 secs
I can't remember whether you still need to be holding the spanner button while doing the last part, but one or other will work!
2007 Daytona RS4 Avant
PetrolDave
Post by PetrolDave » Wed Apr 16, 2008 10:24 am
All those answers only work if you want to reset to fixed interval servicing.
If you have an Audi look here http://www.ross-tech.com/vag-com/cars/audi_sri.html
If you have a VW look here http://www.ross-tech.com/vag-com/cars/vw_sri.html
Sebastian
Post by Sebastian » Wed Apr 16, 2008 10:41 pm
Alternative (for those using "current" versions of the software): Applications > SRI Reset ;)
Sebastian @ Ross-Tech.com
Dom81
Post by Dom81 » Wed Apr 16, 2008 11:17 pm
Wow Sebastian - slick option. Thanks for the update (and another reason why we should use and support Ross-Tech rather then the fleabay leads)
Return to “DTC / VCDS”
