Serial or USB vag.com for RS6?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
GregRS6
Post by GregRS6 » Tue Apr 01, 2008 7:48 pm
Which one do i need for my car chaps, and what is the difference?
The reason way I ask this is because my USB port is broken on my Laptop so idealy i need the serial but is this possible?
Greg
CliveH
RE: Serial or USB vag.com for RS6?
Post by CliveH » Tue Apr 01, 2008 7:58 pm
Doesn't matter - it's just a question of how you plug the lead into the laptop (serial or USB).
The KEY-COM is perfectly adequate for the RS6 (as it doesn't support CAN).
However, although I understand the serial version gives slightly more accurate results, not many laptops have a serial interface these days and if your USB port has broken, how long before the serial port (or the laptop) gives up?
Clive
GregRS6
Post by GregRS6 » Tue Apr 01, 2008 8:15 pm
Nice one Clive, This laptop has been to hell and back, I hope it does'nt give up on me to soon. I ve just started getting internet poker :wink:
Greg
CliveH
Post by CliveH » Tue Apr 01, 2008 8:18 pm
Sorry to hear about the laptop, Greg.
Just bear in mind that if you do go down this route, then you'll be lucky if it works with your next laptop (ie only if the next laptop has a serial port)
Clive
GregRS6
Post by GregRS6 » Tue Apr 01, 2008 8:21 pm
will do Clive
Thanks again
MalcolmSu
Post by MalcolmSu » Wed Apr 02, 2008 8:05 pm
i'd go with serial - even if your later PC/laptop doesn't have a serial port, serial to USB convertors are common
http://www.mrusb.co.uk/catalog/product_ ... cts_id=230
GardinerG
Post by GardinerG » Wed Apr 02, 2008 9:05 pm
Yep, I have a converter for this very reason. It slows the communication rate down but it still works well.
http://www.rs246.com/index.php?name=PNp ... ic&t=68729
Go for the serial lead.
CliveH
Post by CliveH » Wed Apr 02, 2008 10:57 pm
Fair points guys :thumbs:
Clive
PetrolDave
Post by PetrolDave » Thu Apr 03, 2008 11:51 am
GardinerG wrote:Go for the serial lead.
Ross Tech don't recommend using a USB to serial converter.
http://www.ross-tech.com/vag-com/faq_1.html#1.5
If you do use one and you have problems they will NOT give you any support.
The sensible buy is a HEX-USB+CAN.
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 59 guests
