CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!!!!!
ZKNY
RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!
Post by ZKNY » Tue Feb 26, 2008 1:03 am
yes, a smaller plenum it is a little more, NOT "much more" responsive than my custom pieces.
but the tradeoff is the lack of air you get upstairs, where you need it -where the car dies off. especially KO4's on a stock exhaust manifold. w my manifold if you dont pay attention, the tach will bounce off the limiter. that is how much more air is flowed. so yes, not as responsive, but its pretty much a wash as it'll only be 300-500rpms laggier, but once you are on boost, GOODBYE. =D
bottomline, the standard size plenum is too small. i see a mass of people messing around w a lot of different things in search of power yet they have no idea how power is made.
bring on the air! =D
tartan_rob
Post by tartan_rob » Tue Feb 26, 2008 12:24 pm
Why does a larger plenum allow more "air upstairs"?
At that volume of airflow, direct from turbo direct into head is much better surely? Why would you want to keep the plenum charged too?
2017 Kawasaki Z1000
2014 RS6
2014 S1
ZKNY
Re: RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!
Post by ZKNY » Sat Mar 01, 2008 9:30 am
Tartan_Rob wrote:Surely a smaller plenum equates to much more responsive boost as less area to pressurize?
Is it simply a trade off of responsiveness against high boost levels?
it is, but it isnt. high boost levels, <beep> YOU SAY? I <beep> HEAR YOU, LOL =D
the smaller plenum naturally fills quicker, but you die off upstairs -BIGTIME!
but even w a larger plenum, the response is still there (i have video evidence).
its just that the OEM manifold is TOO small, and therefore chokes off the motor. the larger plenum provides all the air you need upstairs -where the car is choked off, and then some.
"high boost" levels have nothing to do w nothing. dont know where that came from. a larger plenum wont change your boost levels. the turbos produce a certain amt of boost... all that is determined way before you get to the manifold.
ZeroK66
RE: Re: RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a k
Post by ZeroK66 » Sat Mar 01, 2008 12:05 pm
Well, my only thought is that in an S4 you can achieve 500BHP on a 2001.5/rs4 manifold. You cant really run anymore power without snapping a rod... if you were planning on running RS6 turbos on RS4 engine end/stronger rods & large heads on S4 bottom end then there would be benifit...
quattrokid1
Post by quattrokid1 » Thu Mar 20, 2008 1:52 am
hmmm REDLINE its there for a reason... not to go there nevermind exceed it!!
so what if someone takes up your advice and blows an engine... are you gonna pay to get it fixed? .....thought so.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
s4woody
Post by s4woody » Thu Mar 20, 2008 4:36 pm
redline is not the limit of the engine..its usually the amount of revs that the power drops off..if you can keep the power past the makers red line then it can be exceeded..but if your planning on doing this then when building your modified engine im sure your'll move the redline up a little higher in the rev range..
GARTH ROAD MOT CENTRE LTD
020 83353032
confusionhunter
Post by confusionhunter » Thu Mar 20, 2008 6:05 pm
also... the redline is the maximum sustainable revs..... sustainable meaning the engines were tested at the redline for X hours.... not just he occasional blip everynow and then through the gears....
The larger plenum acts as a "boost store" so youll get slighlty more air in the cylinders as higher revs
Mark.
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Mar 30, 2008 8:47 am
Relocate the after run pump and yes you can run a larger inlet. Being made now...
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
satanschild
Post by satanschild » Sun Mar 30, 2008 7:55 pm
BRETTCOLLINS wrote:Relocate the after run pump and yes you can run a larger inlet. Being made now...
so you did listen to me then .... :wink:
let me know how you get on with it ...... :thumbs:
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Mar 30, 2008 10:50 pm
Already cut in half mate LOL thanks for the help and the parts..
MING BLUE AUDI S4
Car is on Lock down
satanschild
qick on the job ...
Post by satanschild » Sun Mar 30, 2008 11:01 pm
your very welcome mate .... :thumbs:
if your going to move the after run pump you can eazy get a 3.5 litre plennum in there .. :wink:
BRETTCOLLINS
RE: qick on the job ...
Post by BRETTCOLLINS » Mon Mar 31, 2008 9:07 am
Yes 3.35 litre mate..
MING BLUE AUDI S4
Car is on Lock down
