CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!!!!!
RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!
yes, a smaller plenum it is a little more, NOT "much more" responsive than my custom pieces.
but the tradeoff is the lack of air you get upstairs, where you need it -where the car dies off. especially KO4's on a stock exhaust manifold. w my manifold if you dont pay attention, the tach will bounce off the limiter. that is how much more air is flowed. so yes, not as responsive, but its pretty much a wash as it'll only be 300-500rpms laggier, but once you are on boost, GOODBYE. =D
bottomline, the standard size plenum is too small. i see a mass of people messing around w a lot of different things in search of power yet they have no idea how power is made.
bring on the air! =D
tartan_rob
Why does a larger plenum allow more "air upstairs"?
At that volume of airflow, direct from turbo direct into head is much better surely? Why would you want to keep the plenum charged too?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!
it is, but it isnt. high boost levels, <beep> YOU SAY? I <beep> HEAR YOU, LOL =DTartan_Rob wrote:Surely a smaller plenum equates to much more responsive boost as less area to pressurize?
Is it simply a trade off of responsiveness against high boost levels?
the smaller plenum naturally fills quicker, but you die off upstairs -BIGTIME!
but even w a larger plenum, the response is still there (i have video evidence).
its just that the OEM manifold is TOO small, and therefore chokes off the motor. the larger plenum provides all the air you need upstairs -where the car is choked off, and then some.
"high boost" levels have nothing to do w nothing. dont know where that came from. a larger plenum wont change your boost levels. the turbos produce a certain amt of boost... all that is determined way before you get to the manifold.
RE: Re: RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a k
Well, my only thought is that in an S4 you can achieve 500BHP on a 2001.5/rs4 manifold. You cant really run anymore power without snapping a rod... if you were planning on running RS6 turbos on RS4 engine end/stronger rods & large heads on S4 bottom end then there would be benifit...
- quattrokid1
- Top Gear
hmmm REDLINE its there for a reason... not to go there nevermind exceed it!!
so what if someone takes up your advice and blows an engine... are you gonna pay to get it fixed? .....thought so.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
redline is not the limit of the engine..its usually the amount of revs that the power drops off..if you can keep the power past the makers red line then it can be exceeded..but if your planning on doing this then when building your modified engine im sure your'll move the redline up a little higher in the rev range..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
- confusionhunter
also... the redline is the maximum sustainable revs..... sustainable meaning the engines were tested at the redline for X hours.... not just he occasional blip everynow and then through the gears....
The larger plenum acts as a "boost store" so youll get slighlty more air in the cylinders as higher revs
Mark.
BRETTCOLLINS
- 5th Gear
Relocate the after run pump and yes you can run a larger inlet. Being made now...
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
satanschild
so you did listen to me then ....BRETTCOLLINS wrote:Relocate the after run pump and yes you can run a larger inlet. Being made now...
let me know how you get on with it ......
BRETTCOLLINS
- 5th Gear
Already cut in half mate LOL thanks for the help and the parts..
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
satanschild
qick on the job ...
your very welcome mate ....
if your going to move the after run pump you can eazy get a 3.5 litre plennum in there ..
BRETTCOLLINS
- 5th Gear
RE: qick on the job ...
Yes 3.35 litre mate..
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
