BHP - Torque
musty1
BHP - Torque
Post by musty1 » Tue Mar 25, 2008 1:23 pm
How do convert your BHP to Torque??
1.9TDI A6 are sh*t wrong forum
Blue_Thunder
RE: BHP - Torque
Post by Blue_Thunder » Tue Mar 25, 2008 1:29 pm
Smaller heads? Higher compression ratio?
musty1
RE: BHP - Torque
Post by musty1 » Tue Mar 25, 2008 2:02 pm
sorry I mean figures ie if i have 300 bhp car how do work out the torque
dummi
RE: BHP - Torque
Post by dummi » Tue Mar 25, 2008 2:41 pm
(power x 5252)/ revs = torque
musty1
Post by musty1 » Tue Mar 25, 2008 2:44 pm
cheers :thumbs:
musty1
Post by musty1 » Tue Mar 25, 2008 2:49 pm
the rev is that limit of revs ie 300x5252/7200=218 is that right??
S4TAN
Post by S4TAN » Tue Mar 25, 2008 3:22 pm
That's for torque measured in Nm isn't it? Or is it lbf.ft ... ?
Deus ex machina
dummi
Post by dummi » Tue Mar 25, 2008 3:30 pm
rev's is the point at which you are making max power which will be toward the redline unless u r on k03's lol
in lbft
S4TAN
Post by S4TAN » Tue Mar 25, 2008 3:46 pm
This is good stuff - I've just stacked up the formula against my last RR results; works well, the maths is almost a perfect match for the power and torque curves as plotted against RPM.
Incidentally it shows my power and torque tail off quite steeply beyond 5,500rpm .... I think that must be my optimal point in the rev range to change up a gear .... (but the cooling/air supply was pretty pants on the RR for that session and the car was suffering major heatsoak, so maybe on the "real road" it could be further up the rev range .... maybe 6,000rpm??)
Deus ex machina
musty1
Post by musty1 » Tue Mar 25, 2008 3:47 pm
so if i was to say 300x5252/4800(full boost)=328 right?
bobbler
Post by bobbler » Tue Mar 25, 2008 3:53 pm
My stats are in my sig, so think the resulting value is a ft/lbs?
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
S4TAN
Post by S4TAN » Tue Mar 25, 2008 3:56 pm
Yeah - definitely lbf.ft
Deus ex machina
S4TAN
Post by S4TAN » Tue Mar 25, 2008 3:59 pm
musty1 wrote:so if i was to say 300x5252/4800(full boost)=328 right?
Yes - if you're making 300hp at 4800rpm. Have you got a dyno plot?
Deus ex machina
musty1
Post by musty1 » Tue Mar 25, 2008 4:00 pm
482nm=355 lbf.ft not bad
musty1
Post by musty1 » Tue Mar 25, 2008 4:01 pm
for those that have not draged there car this is a calculator estimating your results
http://www.letstorquebhp.com/calculator.asp
Return to “General Car Chat”
Users browsing this forum: No registered users and 160 guests
