pissed off
pissed off
just fitted rs4 suspension to my 98 s4 and the bastard now sits 15mm higher all round, i thought it would have been 15mm lower , anyone else have this problem ?
fletchie55
Blue_Thunder
- Top Gear
Blue_Thunder
- Top Gear
- ChipHazzard
did you tighten the bolts with the car in the air or on the ground on it's wheel's ? as I think I remember somebody telling me that the car has to be on the ground before finally tightening every thing up to ensure it had settled properly before taking it for a spin
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
I know that applies to wheel bolts - but didn't think it applied to suspension/coilovers! My c/o's were installed at MRC - everything was done and tightened on the 4-point lift (car was in the air)I remember somebody telling me that the car has to be on the ground before finally tightening every thing up to ensure it had settled properly before taking it for a spin
Deus ex machina
all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
What he said. Hand tighten. Let the car settle overnight. Measure the centre of the hubimolas4uk wrote:all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s
to the arch. Jack up and take off wheels. Lift the arm with a jack until it's the same height.
Tighten everything to specified torque. (you can leave out the settle overnight bit if you
want, any movement should be within tolerance).
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: Google [Bot] and 56 guests
