pissed off
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
curtis11
pissed off
Post by curtis11 » Wed Mar 19, 2008 7:34 pm
just fitted rs4 suspension to my 98 s4 and the bastard now sits 15mm higher all round, i thought it would have been 15mm lower , anyone else have this problem ?
TopBear
Post by TopBear » Wed Mar 19, 2008 7:52 pm
Did you put it on upside down?
.....sorry, couldnt resist :wink:
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
buzzard
Post by buzzard » Wed Mar 19, 2008 8:28 pm
take out the axle stands... :shock:
S4 B5 long gone
S4 B8 Stage 2
curtis11
Post by curtis11 » Wed Mar 19, 2008 8:30 pm
anyone on here apart from dickheads?
fletchie55
Post by fletchie55 » Wed Mar 19, 2008 8:34 pm
is yours the avant? think the avant springs are a bit harder to account for the extra weight. This might make the car sit a bit higher. also might need a bit of time to settle in, but 15mm sounds a lot
Blue_Thunder
Post by Blue_Thunder » Wed Mar 19, 2008 8:36 pm
I reckon it will settle. Although as mentioned by Fletchie, if you've fitted RS4 springs to a saloon, the arse end will stick up a little more.
curtis11
Post by curtis11 » Wed Mar 19, 2008 8:40 pm
sorry its a saloon
Blue_Thunder
Post by Blue_Thunder » Wed Mar 19, 2008 8:51 pm
When my car first had coilovers fitted it didn't look too low. After a couple of days they must have dropped by about 15mm.
Don't worry about the look too much, it's the improved performance that will put the smile on your face :D
curtis11
Post by curtis11 » Wed Mar 19, 2008 9:00 pm
well the ride is just about perfect, and new control arms made a world of difference to the drive
S4TAN
Post by S4TAN » Wed Mar 19, 2008 9:02 pm
Should settle curtis .... take a car load of fat blokes* for a good spin on some bumpy roads - that'll sort it.
* or fat chicks (I'm not sexist)
Deus ex machina
ChipHazzard
Post by ChipHazzard » Wed Mar 19, 2008 9:07 pm
did you tighten the bolts with the car in the air or on the ground on it's wheel's ? as I think I remember somebody telling me that the car has to be on the ground before finally tightening every thing up to ensure it had settled properly before taking it for a spin
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
S4TAN
Post by S4TAN » Wed Mar 19, 2008 9:10 pm
I know that applies to wheel bolts - but didn't think it applied to suspension/coilovers! My c/o's were installed at MRC - everything was done and tightened on the 4-point lift (car was in the air)
Deus ex machina
DavidT
Post by DavidT » Wed Mar 19, 2008 9:27 pm
Do you know what suspenstion it had on before curtis11?
Measure it from the wheel arch to the ground in a couple of days & do a search on this forum for comparative info.
imolas4uk
Post by imolas4uk » Wed Mar 19, 2008 10:52 pm
all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s :thumbs:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
JonnyX
Post by JonnyX » Thu Mar 20, 2008 10:41 am
imolas4uk wrote:all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s :thumbs:
What he said. Hand tighten. Let the car settle overnight. Measure the centre of the hub
to the arch. Jack up and take off wheels. Lift the arm with a jack until it's the same height.
Tighten everything to specified torque. (you can leave out the settle overnight bit if you
want, any movement should be within tolerance).
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Users browsing this forum: Majestic-12 [Bot] and 80 guests
