Cold rev limit
Cold rev limit
Having had my car re-mapped by Jeroen at JDE, included was a lowering of the cold running upper rev limit to 4,000 rpm. However, the Driver Info Display still reads 7,000 rpm. Any clever techies out there know how to change the reading?
RS4 B7 Phantom Black
RE: Cold rev limit
If you do change the reading, the Service team will know you've tampered, beware; the germans are puting more "Feedback INFO" into there cars now, this info is accessed once the car is coupled to the computer systems @ said service centre. This can lead too lost warrantee.
Be careful.
Be careful.
- PetrolDave
RE: Cold rev limit
Not seen any way of doing it. I reckon it's "hard coded" into the instrument cluster.
Cold rev limit
The service team are going to know anyway when the engine bounces off the rev limiter at 4,000 rpm!
RE: Cold rev limit
properly think it is a fault, LOL and report it to Audi ...
RS4 Avant - Sold Aug 2009
I thought the 7,000rpm rev limit was purely an advisory message on the DIS rather than a physical rev limiter. Obviously I've never felt the need to check this. I'm sure that I read it in the handbook but I can't be bothered going out to the garage to check right now.............could be wrong.
I assume that you have tried out the 4,000rpm limiter since having it re-mapped.
The 7 k limit does cut the power and the 4k limit JD Eng sets it at works too, although he will set it to any limit you want.Iain_S4 wrote:I thought the 7,000rpm rev limit was purely an advisory message on the DIS rather than a physical rev limiter. Obviously I've never felt the need to check this. I'm sure that I read it in the handbook but I can't be bothered going out to the garage to check right now.............could be wrong.
I've asked to have that limiter set at 5000rpm as 4000rpm can be reached quickly.... but 7000rpm is really too high OEM...
AUDI RS5 B9 (2017-2019)
AUDI A6 AVANT 4G (2012-2016
AUDI RS5 B8 (2010-2012)
AUDI A4 AVANT B8 2.0 TD I 120hp, upgraded to 184ch/442Nm used as daily car (09-12)
AUDI A4 RS4 V8 upgraded to with +35hp/+30Nm) (06-08)
PORSCHE 996 TT upgraded to 500hp/700Nm (05-06)
