Boost Drop - What could be the cause?
rs-mad
Post by rs-mad » Tue Mar 11, 2008 12:38 am
Hi,
Just looking for some ideas that you guys may have as to why my boost curve has dropped off as opposed to holding boost as it normally does?
The image attached shows what the boost curve should be and what is it.
I have a feeling it is a boost leak and will be looking at the fuel trims later today but just want to know if anyone has seen anything like this before I go looking
Thanks in advance.
RS-MAD
Boost Cuve - Normal v Not Normal.JPG (64.61 KiB) Viewed 1001 times
S2tuner
Trader (Expired)
RE: Boost Drop - What could be the cause?
Post by S2tuner » Tue Mar 11, 2008 12:56 am
I don't think it's a leak, as the boost you're holding at redline is identical to the "normal" curve.
rs-mad
Post by rs-mad » Tue Mar 11, 2008 1:06 am
S2Tuner - Thanks for replying.
What you say does make sense as the requested boost for both curves is pretty much the same.
But boost has dropped off at 3500rpm as opposed to holding until ~5000rpm.
RS-MAD
flashyg
Post by flashyg » Tue Mar 11, 2008 1:49 am
Boost controllers get tired. try changing usually clears up this mid drop issue.
rs-mad
Post by rs-mad » Tue Mar 11, 2008 1:53 am
You mean the N75 valve?
RS-MAD
rs-mad
Post by rs-mad » Tue Mar 11, 2008 4:29 am
Just went a and logged:
MB032 (Stored and Idle Values)
MB033 (Idle values)
RS-MAD
MB032 Stored Value.xls
(13.5 KiB) Downloaded 60 times
MB033 Idle.xls
(26 KiB) Downloaded 61 times
MB032 Idle.xls
(84.5 KiB) Downloaded 46 times
Nige_RS4
Post by Nige_RS4 » Tue Mar 11, 2008 9:48 am
When you say normal and not normal, do you mean requested and actual or are you comparing a boost log from a different day? If from a different day, then there could be any number of factors that could change your boost curve slightly. There doesn't seem to be any units of measurement on the vertical axis?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
rs-mad
Post by rs-mad » Tue Mar 11, 2008 11:18 am
Nige - The boost decrease has been more than what would normally occur on a day to day.
See new curve
Normal = What boost should be
Not Normal = What boost is and shouldnt be
RS-MAD
rs-mad
Post by rs-mad » Sat Mar 15, 2008 8:29 am
Problem diagnosed
RS-MAD
Blue_Thunder
Post by Blue_Thunder » Sat Mar 15, 2008 10:22 am
What was the issue?
And i'm still unclear what you meant by your 'Normal' boost curve. As Nige asked, was this what you've previously logged as your actual boost on the car, or was this the specified boost?
Users browsing this forum: No registered users and 81 guests
