Boost Drop - What could be the cause?
Hi,
Just looking for some ideas that you guys may have as to why my boost curve has dropped off as opposed to holding boost as it normally does?
The image attached shows what the boost curve should be and what is it.
I have a feeling it is a boost leak and will be looking at the fuel trims later today but just want to know if anyone has seen anything like this before I go looking
Thanks in advance.
RS-MAD
Thanks in advance.
RS-MAD
- Attachments
- Boost Cuve - Normal v Not Normal.JPG (64.61 KiB) Viewed 995 times
RE: Boost Drop - What could be the cause?
I don't think it's a leak, as the boost you're holding at redline is identical to the "normal" curve.
Just went a and logged:
MB032 (Stored and Idle Values)
MB033 (Idle values)
RS-MAD
MB033 (Idle values)
RS-MAD
- Attachments
- MB032 Stored Value.xls
- (13.5 KiB) Downloaded 59 times
- MB033 Idle.xls
- (26 KiB) Downloaded 61 times
- MB032 Idle.xls
- (84.5 KiB) Downloaded 46 times
When you say normal and not normal, do you mean requested and actual or are you comparing a boost log from a different day? If from a different day, then there could be any number of factors that could change your boost curve slightly. There doesn't seem to be any units of measurement on the vertical axis?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Blue_Thunder
- Top Gear
