Indicator problem
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
JonnyX
Indicator problem
Post by JonnyX » Mon Feb 25, 2008 1:03 pm
Hi,
Both my indicators (left and right) have started playing up.
The bulbs are fine.
The speed is not consistent and they have no just started stopping after a couple
of blinks - relay bad?
Cheers,
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
GardinerG
RE: Indicator problem
Post by GardinerG » Mon Feb 25, 2008 1:04 pm
Yep, sounds like a duff relay.
MarkB
Post by MarkB » Mon Feb 25, 2008 1:07 pm
Yep the one behind the hazard switch.
Mark
JonnyX
Post by JonnyX » Mon Feb 25, 2008 2:08 pm
Great, thanks chaps.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Feb 25, 2008 10:10 pm
Part of the hazard switch.....
Virdee Autos ~ 07950-526592
JonnyX
Post by JonnyX » Tue Feb 26, 2008 2:35 pm
OK, next question. How the f*** are you meant to get these things out?
I have managed to break the old relay AND the cup holder trying to do this. :bash:
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
JonnyX
Post by JonnyX » Tue Feb 26, 2008 3:25 pm
Just done it. I needed my trusty butter knife. Bit of a pain in the arse.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Feb 26, 2008 8:59 pm
I did one the other day, and the best method I found was by breaking off the top edge, and then sliding a hook behind it, and levering it out.
Danian
Post by Danian » Wed Feb 27, 2008 1:16 am
I broke the front off (you might as well it's knackered anyway) giving me something to grip with a pair of pliars. Then just pull hard untill it comes out.
B5 S4
B8.5 S4
MCB
Post by MCB » Wed Feb 27, 2008 8:43 pm
Only just noticed this post, following link posted in B5 S4: "How to..." link here in case anyone else needs to do this:
http://forums.audiworld.com/s4/msgs/1783172.phtml
S4B5 Avant
SunDiver
Post by SunDiver » Mon Sep 01, 2008 5:23 pm
My indicators were failing. Bought a new relay from VagParts for £20 - just swapped it in. Here's how I did it - took five minutes.
Popped off trim. Got some mole grips and adjusted them such one side of the teeth lay flat along the bottom of the red triangle and the other lay against the upper point of the triangle. Swift pull and the red switch bit came away leaving the inner relay box and a couple of springs showing - it's knackered anyway so no loss. Adjusted the mole grips down such that I could grab the relay box itself - or rather the edge of it - one set of teeth on the inside now, the other on the outside lip. Another tug at it and the whole thing came out. Uplugged it from the wiring harness, plugged the new one in, tested it. All fine so pushed it home and all done.
I didn't have to use much force or wrestle with it much - just make sure the grips have a good hold and yank backwards.
It's pleasing to have fully working indicators again!
Users browsing this forum: Majestic-12 [Bot] and 50 guests
