k16/24 porsche hybrid turbo's with 1 point comp drop gaskets
dummi
Post by dummi » Sat Feb 16, 2008 9:56 pm
these are used set 3000 miles of k16 turbo's with k24 compressor wheel built by DMS Automotive porsche specialists. exhaust housing and turbine are k16 flow plenty for 2.7 , k24 compressor wheel flows more than the original wheel for earlier boost
as they're used they'll need a rebuild
also included is a 1 point compression drop gasket set, should drop rs4 to 8.3 from 9.3, and s4 from 8.8 to 7.8, have i got that right?
S2tuner
Trader (Expired)
RE: k16/24 porsche hybrid turbo
Post by S2tuner » Sat Feb 16, 2008 10:35 pm
How much for the turbos?
dummi
Post by dummi » Sat Feb 16, 2008 10:56 pm
you have a pm
dummi
Post by dummi » Tue Feb 19, 2008 6:35 am
few things to add
-weld on adapters for k16 turbine housing inlet
-3" ASP downpipes with k16 flange
makes it practically bolt on for rs4 with the gasket change
for s4 i have some rs4 intake parts - turbo inlet pipes rubber pipes, RS4 y pipe, RS4 airbox and MAF and accordian
MarkB
Re: RE: k16/24 porsche hybrid turbo
Post by MarkB » Tue Feb 19, 2008 9:11 am
How much for this little lot?
Mark
dummi
RE: Re: RE: k16/24 porsche hybrid turbo
Post by dummi » Tue Feb 19, 2008 10:49 am
you have a PM
saf
Post by saf » Tue Feb 19, 2008 4:15 pm
You have PM
dummi
Post by dummi » Tue Feb 19, 2008 9:22 pm
you have pm reply
dummi
Post by dummi » Wed Feb 20, 2008 5:48 pm
these parts are practically sold
same buyer is reserving k16/24 + dp's and flanges for the next week
other items i have found of interest are pair of forge diverter valves with piston and spring kits in black new
a set of audi TT rims with kerbing, they are taking up space so i will take offers
dodgydave
Re: k16/24 porsche hybrid turbo's with 1 point comp drop gas
Post by dodgydave » Fri Feb 22, 2008 9:05 pm
dummi wrote:these are used set 3000 miles of k16 turbo's with k24 compressor wheel built by DMS Automotive porsche specialists. exhaust housing and turbine are k16 flow plenty for 2.7 , k24 compressor wheel flows more than the original wheel for earlier boost
Dummi,
FYI: S4 stock static CR is: 9.3:1, RS4 stock static CR is: 9.0:1
Also, no steel layered dropping gasket will give you a 1.0 drop. The most you get safely out of a layered gasket is about 0.4. If you want more you'll need pistons or run a copper spacer plate with orings.
Regards,
Dave
Never enough...
dummi
RE: Re: k16/24 porsche hybrid turbo
Post by dummi » Fri Feb 22, 2008 9:23 pm
thanks
dummi
Post by dummi » Fri Feb 22, 2008 9:26 pm
as i recall 0.7 gaskets do ok, if you were wanting to be safe oring and headstud i agree. it is steel so only the smallest amount of oringing
dummi
Post by dummi » Tue Feb 26, 2008 7:14 am
parts still available
- RS4 turbo pipes and rubber links to y-pipe
- two forge billet diverter valves in black with spring kits
- 1 point drop gaskets
- TT rims
Users browsing this forum: Google [Bot] and 70 guests
