k16/24 porsche hybrid turbo's with 1 point comp drop gaskets
these are used set 3000 miles of k16 turbo's with k24 compressor wheel built by DMS Automotive porsche specialists. exhaust housing and turbine are k16 flow plenty for 2.7 , k24 compressor wheel flows more than the original wheel for earlier boost
as they're used they'll need a rebuild
also included is a 1 point compression drop gasket set, should drop rs4 to 8.3 from 9.3, and s4 from 8.8 to 7.8, have i got that right?
RE: k16/24 porsche hybrid turbo
you have a pm
few things to add
-weld on adapters for k16 turbine housing inlet
-3" ASP downpipes with k16 flange
makes it practically bolt on for rs4 with the gasket change
for s4 i have some rs4 intake parts - turbo inlet pipes rubber pipes, RS4 y pipe, RS4 airbox and MAF and accordian
Re: RE: k16/24 porsche hybrid turbo
Mark
RE: Re: RE: k16/24 porsche hybrid turbo
you have a PM
You have PM
you have pm reply
these parts are practically sold
same buyer is reserving k16/24 + dp's and flanges for the next week
other items i have found of interest are pair of forge diverter valves with piston and spring kits in black new
a set of audi TT rims with kerbing, they are taking up space so i will take offers
Re: k16/24 porsche hybrid turbo's with 1 point comp drop gas
Dummi,dummi wrote:these are used set 3000 miles of k16 turbo's with k24 compressor wheel built by DMS Automotive porsche specialists. exhaust housing and turbine are k16 flow plenty for 2.7 , k24 compressor wheel flows more than the original wheel for earlier boost
FYI: S4 stock static CR is: 9.3:1, RS4 stock static CR is: 9.0:1
Also, no steel layered dropping gasket will give you a 1.0 drop. The most you get safely out of a layered gasket is about 0.4. If you want more you'll need pistons or run a copper spacer plate with orings.
Regards,
Never enough...
RE: Re: k16/24 porsche hybrid turbo
as i recall 0.7 gaskets do ok, if you were wanting to be safe oring and headstud i agree. it is steel so only the smallest amount of oringing
parts still available
- RS4 turbo pipes and rubber links to y-pipe
- two forge billet diverter valves in black with spring kits
- 1 point drop gaskets
- TT rims
- TT rims
