I thought H&R only did a 17mm and 22mm rear bar?BRETTCOLLINS wrote:My Car is only running the 19mm rear H&R bar and the sub frame is fine..MarkB wrote:I need to replace a rusty Milltek clamp at the weekend so I'll take a look at my subframe. I'm only running a 19mm rear bar so it may not have put as much stress on the frame...
What sort of miles have people run to get the cracking?
Snapped rear subframe
Mark
That's what I would like to do. Weld up the flanges for the ARB mounts and add someMarkB wrote:Can it not be welded and additional strengthening?
Looks like quite a few hours labour to change and then you'll need a full alignment.
'eyelets' for the link arm attachment points. Anyone know of a garage in the
Farnborough/Camberley/Guildford area that might take on custom work like this?
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Jon, i am right in saying that the H+R rear kit comes with No extra strength brackets?
http://www.neuspeed.com/products/produc ... o&p_id=242
has some really nice ones in the kit... Why would all the other makes do brackets, H-sport are the same, extra brackets.
look at these as well http://shopwiki.com/detail/q=H-Sport+Sw ... irst=true/
H+R are talking SH*T loads of probs in the US and here
Darren
Darren
Yep, that's what I think too. I have posted on AW asking for some stories. However, I need evidence really rather than
anecdotes. I will photograph my car but it would help if others had the same problem with H&R and had documented it.
The fact that nearly all other manufacturers include support brackets is pretty enlightening I think.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- mikeyquattro
- Top Gear
- 5th Gear
talk to gordon aka flashy g hes just had the same problem and got it welded back together with extras.
665 bhp + 586 lbft...
H+R Again. big rear bar?Danian wrote:Checked my subframe today and there are cracks appearing. Very small at the moment but signs of stress all over the piece that the ARB bolts to. This appears to be a common problem and one that H&R should be aware of. Is being a member of a forum like being a member of a union?
Darren
i think it is just prefacelifts are older and rustier - looks like it will be a problemon all cars. I am getting some braces designed just now.
http://www.MRCtuning.com
