193 bhp heads on S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
matias
193 bhp heads on S4
Post by matias » Fri Feb 15, 2008 7:12 pm
Is there any problem in fitting some heads from a V6 non turbo engine, in a S4?
dummi
RE: 193 bhp heads on S4
Post by dummi » Fri Feb 15, 2008 10:46 pm
only cams and exhaust valves, use your S4 ones in them
matias
Post by matias » Sat Feb 16, 2008 3:12 am
If I want to fit the head from a non turbo 30V, I must then use my S4 cams and exhaust valves?????
rikrose
Post by rikrose » Sat Feb 16, 2008 3:14 am
Well, I suppose you could not bother to do so, if you don't want it to work.
Goodwood green RS4, previously owned by jeffw
okkim
Post by okkim » Sat Feb 16, 2008 9:39 am
Exhaust cams are the same. Exhaust valves are sodium filled in S4 and RS4, and the exhaust valve springs are different. So you should use those from the S4 head.
The inlets are much wider in the 2.8 head, so you sholud port the intake manifold or change it to the RS4 intake.
satanschild
Post by satanschild » Sat Feb 16, 2008 2:13 pm
if the heads you plan to use are from a 2.4 then you can just bolt them straight on ...
you dont have to change the exhaust valves, BUT the s4/rs4 exhaust valves as the guys have stated they are sodium filled and transfer heat better ...
the cams from a pair 2.4 heads are the same as cams in rs4 heads...
they will work no differently left as they are tho..... :thumbs:
i am running a pair of ported 2.4 heads .....
ill post some pics soon
40mm exhaust ports......... :shock:
dummi
RE: ...
Post by dummi » Sat Feb 16, 2008 9:38 pm
put some pics up satanschild i want to see what you've gone and done :P
AdamS4
RE: ...
Post by AdamS4 » Sun Feb 17, 2008 12:36 pm
What model of the A4 has the 2.4 engine ?
saf
Re: RE: ...
Post by saf » Sun Feb 17, 2008 12:41 pm
AdamS4 wrote:What model of the A4 has the 2.4 engine ?
The 2.4 model which would be a B5. I can remember there being some early B6's as well.
Siena
RE: Re: RE: ...
Post by Siena » Sun Feb 17, 2008 3:14 pm
2.4 only came in B5 chassis, as well as C5.
satanschild
Re: RE: ...
Post by satanschild » Sun Feb 17, 2008 8:57 pm
dummi wrote:put some pics up satanschild i want to see what you've gone and done :P
:roll: oh if i must .... lol
before, you can notice the massive lip left when machined for the valve seats...
and after...
and the exhaust port polished ....
its took me about 9 hours to do one head ...
satanschild
2.4 heads ...
Post by satanschild » Sun Feb 17, 2008 8:58 pm
ill also post all the pics in my thread.... :thumbs:
saf
Re: RE: Re: RE: ...
Post by saf » Sun Feb 17, 2008 11:41 pm
Siena wrote:2.4 only came in B5 chassis, as well as C5.
Yes and the B6 A4. Uptill 2005 (55 plate)
A lot of the A4 B6 cabriolet's had 2.4 heads.
quattronutter
Re: RE: ...
Post by quattronutter » Mon Feb 18, 2008 1:07 am
and after...
nice work there,i know how time consuming it is,no quick way if you want it right though
team_soy
RE: Re: RE: ...
Post by team_soy » Tue Feb 19, 2008 6:20 pm
wow those those pics are amazing
Users browsing this forum: No registered users and 99 guests
