193 bhp heads on S4
193 bhp heads on S4
Is there any problem in fitting some heads from a V6 non turbo engine, in a S4?
RE: 193 bhp heads on S4
only cams and exhaust valves, use your S4 ones in them
If I want to fit the head from a non turbo 30V, I must then use my S4 cams and exhaust valves?????
Well, I suppose you could not bother to do so, if you don't want it to work.
Goodwood green RS4, previously owned by jeffw
Exhaust cams are the same. Exhaust valves are sodium filled in S4 and RS4, and the exhaust valve springs are different. So you should use those from the S4 head.
The inlets are much wider in the 2.8 head, so you sholud port the intake manifold or change it to the RS4 intake.
satanschild
if the heads you plan to use are from a 2.4 then you can just bolt them straight on ...
you dont have to change the exhaust valves, BUT the s4/rs4 exhaust valves as the guys have stated they are sodium filled and transfer heat better ...
the cams from a pair 2.4 heads are the same as cams in rs4 heads...
they will work no differently left as they are tho.....
i am running a pair of ported 2.4 heads .....
ill post some pics soon
40mm exhaust ports.........
Re: RE: ...
The 2.4 model which would be a B5. I can remember there being some early B6's as well.AdamS4 wrote:What model of the A4 has the 2.4 engine ?
RE: Re: RE: ...
2.4 only came in B5 chassis, as well as C5.
satanschild
Re: RE: ...
dummi wrote:put some pics up satanschild i want to see what you've gone and done
before, you can notice the massive lip left when machined for the valve seats...
and after...
and the exhaust port polished ....
its took me about 9 hours to do one head ...
satanschild
2.4 heads ...
ill also post all the pics in my thread....
Re: RE: Re: RE: ...
Yes and the B6 A4. Uptill 2005 (55 plate)Siena wrote:2.4 only came in B5 chassis, as well as C5.
A lot of the A4 B6 cabriolet's had 2.4 heads.
quattronutter
Re: RE: ...
nice work there,i know how time consuming it is,no quick way if you want it right thoughsatanschild wrote:dummi wrote:put some pics up satanschild i want to see what you've gone and doneoh if i must .... lol
and after...
RE: Re: RE: ...
wow those those pics are amazing
Users browsing this forum: No registered users and 104 guests
