Logging Air/Fuel Ratio
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
DavidT
Post by DavidT » Sun Feb 03, 2008 12:42 pm
Folks,
How do I do this on my 2000 model S4 please ? :)
Also, where do I find any other related info, like long term fuel trim etc.
Thanks in advance,
David
S2tuner
Trader (Expired)
RE: Logging Air/Fuel Ratio
Post by S2tuner » Sun Feb 03, 2008 2:45 pm
You can't log proper AFR on an S4, unless you put a wideband O2 sensor in the exhaust ;)
DavidT
Post by DavidT » Mon Feb 04, 2008 4:18 pm
Thanks Mihnea,
How do I know how the car is running then :( I know the long term trims are engine block 032 but how do you measure a/f when you map them ?
jeffw
Post by jeffw » Mon Feb 04, 2008 4:34 pm
He uses a Wideband 02 sensor to map....not as pricy as they used to be, I bought one to map the Kit Car and it cost something like £100 including the gauge.
DavidT
Post by DavidT » Mon Feb 04, 2008 4:39 pm
Ta Jeff. he didn't use one on any of my maps IIRC.
jeffw
Post by jeffw » Mon Feb 04, 2008 5:02 pm
Really....he did first time on mine, then trims where used..
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Feb 04, 2008 5:13 pm
I have one fitted to my car. got it from theses people.
http://www.turbobits.co.uk/acatalog/Inn ... gauge.html
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
jeffw
Post by jeffw » Mon Feb 04, 2008 5:33 pm
THis is the one I bought from the states
http://www.diyautotune.com/catalog/inno ... p-153.html
DavidT
Post by DavidT » Mon Feb 04, 2008 5:39 pm
Thanks guys, I feel the need for one of these gadgets :)
When I was at MRC last, Doug showed me an LED display that could do EGT, A/F ratio & other stuff (forgot what!) it looked very cool.
I would still like to be able to log a/f though, can you just change the exhaust sensors ? I fancy doing this and wideband EGT sensors too.
jeffw
Post by jeffw » Mon Feb 04, 2008 5:47 pm
Certainly the Megasquirt ECU I'm using for the kit car will log AFR....not sure about the Audi though.
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Feb 18, 2008 10:46 am
this kit that I use can be logged on the laptop. the software will let you log upto 5 other sensors to..
MING BLUE AUDI S4
Car is on Lock down
DavidT
Re: RE: Logging Air/Fuel Ratio
Post by DavidT » Mon Feb 18, 2008 10:48 am
jeffw wrote:Certainly the Megasquirt ECU I'm using for the kit car will log AFR....not sure about the Audi though.
:assflash: to you then :)
jeffw
RE: Re: RE: Logging Air/Fuel Ratio
Post by jeffw » Mon Feb 18, 2008 2:26 pm
DavidT
Post by DavidT » Mon Feb 18, 2008 6:58 pm
So Mihnea, can wideband O2 sensors be installed & logged with VAG-COM ? :)
S2tuner
Trader (Expired)
Re: RE: Re: RE: Logging Air/Fuel Ratio
Post by S2tuner » Mon Feb 18, 2008 8:03 pm
DavidT wrote:So Mihnea, can wideband O2 sensors be installed & logged with VAG-COM ? :)
on a 2.7T: NO, and it's not a happy "no", because it has been on my drawing board for a few months, this idea to try and get the stock ECU to work with wideband O2 sensors. Unfortunately the hardware is not up to the task, and the only way around it would be to upgrade the ECU to a later one from an Allroad, that had dual widebands, but that is definitely not practical.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 26 guests
