yes it will depending on how much time and effort is put into prep and paint,also depends on the quality of the mouldsrikrose wrote:Every carbon fibre item I've sene has ahd the carbon fibre look, to show that it is CF. Looks very race car. Question is, will CF take a layer of primer and some paint, and blend with what I've got already?
CARBON FIBRE PANELS
quattronutter
- Virdee Autos
- Trader (Expired)
Yep as stated, takes alot of prep time to get right, otherwise you'll see the carbon weave in some areas if not done totally right.
Edited to say IMO, bare carbon is so last year! Only small items like lip spoilers, and boot lip spoilers are ok in bare cf, but larger items like bonnets, and tailgates need to be painted IMHO!
Virdee Autos ~ 07950-526592
BRETTCOLLINS
- 5th Gear
unless you have an M3 CSL..they dont paint the roof..larger items like bonnets, and tailgates need to be painted IMHO!
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
- Virdee Autos
- Trader (Expired)
Roof is probably the only large part which you can get away with. It's so high up, some won't even notice, especially on a dark coloured car.
BRETTCOLLINS
- 5th Gear
I think if you can get a solution that is not wet layup (looks cheap and halfords like), that is not full dry pre preg carbon with autoclave (very expensive to tool never mind cure) then it will be possible at reasonable cost. My personal favourite is between the oven cured pre preg, which is still vacuumed, or the resin infused process. Both are cheaper than the full dry, but more expensive than the wet, but you still get a semi-dry finish as per the proper autoclave stuff - it's just some resin will remain in the weave.
Be interesting to see what process is used here, may even be interested in joining the groups buy if it comes off
Cheers,
Andiroo
Cheers,
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
satanschild
the other way round rik .....rikrose wrote:There's lots of ways of preparing Carbon Fibre. The more expensive it is, the better it takes paint. It gets very expensive, and looks better. We want to go to the middle.
cheap resin models will take paint better as you only need to flat down the resin with a DA and 1200, then is ready for paint.
pre preg and dry will need a good filler primer so to smooth out the weave...
ps. andiroo im on the case already, andy has a good man for us........
Any further news on the type of process quattronutter?
Cheers,
Andiroo
Cheers,
Andiroo
True
Always leave unpainted in that loverly matt finish IMHO
Althought the 996 Cup I had had a light silver finish over the carbon front and rear, looked quite nice as you could see the weave thru the paint.
Cheers,
Andiroo
Cheers,
Andiroo
- Attachments
- 996 cup.jpg (65.8 KiB) Viewed 1136 times
- GL20050903CroftIMG_0622 (Medium).JPG (52.61 KiB) Viewed 1132 times
