Oil in Turbo inlet pipe !
Guys
Had my RS4 into the garage ( again ) and the mechanics continue to tell me my turbo's are needing replaced due to leaks inside the housing that can't be reached ? They have a couple of pics taken showing oil inside the pipe ( dont know which pipe it is as i am not that techy.
I am obviously not keen on replacing the turbos unnecessarily especially as the engine seems to be working fine at the moment , having replaced the MAF, DV's and N75 thingy.
There is also no bad whining noise or any mechanical sounds that give me cause for their being a major turbo failure. No smoke either, just sometimes burning smells from something burning on start up which eventually goes away.
Any thoughts from the expert knowledge base here that could help me in solving the oil leakage issue and working out if the turbos are the problem ?
Unfortunately as i live in Hong Kong, popping over to MRC is not on my list of options... The guys at the garage should know what they are doing as the manager used to have an RS4, so i am inclined to accept their advice, but the expense is daunting...
many thanks
soapy
many thanks
soapy
- Attachments
- RHD, taken from drivers side over engine, Can see lots of greasy dirt below the pipe where it must be leaking.
- oil in pipe.JPEG (187.75 KiB) Viewed 947 times
- oil in pipe2.jpeg (146.72 KiB) Viewed 949 times
RE: Oil in Turbo inlet pipe !
The oil is from the PCV system. It's condensed oil vapour from the crankcase and cam covers. If it's really bad
then it can be a sign of worn piston rings. It's definitely not turbos, leaky turbos end up in the exhaust.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- nickelvery
Mines got more oil than that, is there any way of telling if the piston rings are worn apart from removing the head?
The next AudiMeets event is Sunday 13th July
www.AudiMeets.co.uk
http://i82.photobucket.com/albums/j250/ ... banner.jpg
www.AudiMeets.co.uk
- nickelvery
A slight relief thanks.
www.AudiMeets.co.uk
www.AudiMeets.co.uk
- nickelvery
Thanks ever so much, what a pal!!GardinerG wrote:Hey Nick, I'll pour some oil in next time I see you if you like?!?
J/k
Will we be graced with your presence at the meet on the 2nd. People are coming from all over so no excuses!!
www.AudiMeets.co.uk
www.AudiMeets.co.uk
Why don't you just take a spark plug out and do a compression test? You can get a compression gauge from an auto parts shop. If you squirt some oil in and the compression goes up then you know there's a prob with the rings though you might need to check the valve guides as well but getting a bit beyond my expertise now.nickelvery wrote:Mines got more oil than that, is there any way of telling if the piston rings are worn apart from removing the head?
Users browsing this forum: No registered users and 81 guests
