Oil in Turbo inlet pipe !
2.7 V6 30v biturbo - 380 bhp
soapy_g
Post by soapy_g » Fri Feb 01, 2008 3:49 pm
Guys
Had my RS4 into the garage ( again ) and the mechanics continue to tell me my turbo's are needing replaced due to leaks inside the housing that can't be reached ? They have a couple of pics taken showing oil inside the pipe ( dont know which pipe it is as i am not that techy.
I am obviously not keen on replacing the turbos unnecessarily especially as the engine seems to be working fine at the moment , having replaced the MAF, DV's and N75 thingy.
There is also no bad whining noise or any mechanical sounds that give me cause for their being a major turbo failure. No smoke either, just sometimes burning smells from something burning on start up which eventually goes away.
Any thoughts from the expert knowledge base here that could help me in solving the oil leakage issue and working out if the turbos are the problem ?
Unfortunately as i live in Hong Kong, popping over to MRC is not on my list of options... The guys at the garage should know what they are doing as the manager used to have an RS4, so i am inclined to accept their advice, but the expense is daunting...
many thanks
soapy
RHD, taken from drivers side over engine, Can see lots of greasy dirt below the pipe where it must be leaking.
oil in pipe.JPEG (187.75 KiB) Viewed 948 times
oil in pipe2.jpeg (146.72 KiB) Viewed 950 times
MarkB
RE: Oil in Turbo inlet pipe !
Post by MarkB » Fri Feb 01, 2008 3:56 pm
It's normal.
Mark
JonnyX
Post by JonnyX » Fri Feb 01, 2008 4:07 pm
The oil is from the PCV system. It's condensed oil vapour from the crankcase and cam covers. If it's really bad
then it can be a sign of worn piston rings. It's definitely not turbos, leaky turbos end up in the exhaust.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
soapy_g
Post by soapy_g » Fri Feb 01, 2008 4:09 pm
Thanks guys for the prompt replies !
That has really put my mind at rest - now i can spend the cash on something nice like the brake upgrade and perhaps more...
cheers
soapy
nickelvery
Post by nickelvery » Fri Feb 01, 2008 5:24 pm
Mines got more oil than that, is there any way of telling if the piston rings are worn apart from removing the head?
MarkB
Post by MarkB » Fri Feb 01, 2008 5:27 pm
I wouldn't worry until you are down on power or creating a James Bond style smoke screen
Mark
nickelvery
Post by nickelvery » Fri Feb 01, 2008 5:29 pm
A slight relief thanks.
GardinerG
Post by GardinerG » Fri Feb 01, 2008 5:42 pm
Hey Nick, I'll pour some oil in next time I see you if you like?!? :D
J/k
nickelvery
Post by nickelvery » Fri Feb 01, 2008 5:50 pm
GardinerG wrote:Hey Nick, I'll pour some oil in next time I see you if you like?!? :D
J/k
Thanks ever so much, what a pal!! :D
Will we be graced with your presence at the meet on the 2nd. People are coming from all over so no excuses!!
GardinerG
Post by GardinerG » Fri Feb 01, 2008 8:20 pm
Not sure if graced is the word I'd use! Hmmm there are some quite good "clubs" in Birmingham....but one of those nights out is on a par with the cost of a Milltek. lol. Will have to see ;-)
P.s. Sorry for the OT chat!
lengster1
Post by lengster1 » Sat Feb 02, 2008 12:38 am
Mine had this noted at its 50k service,audi reckoned the same turbos on the way out so replaced them under warranty,i obviously didnt argue but know its normal,it made no difference to the level of oil in the pipework but nice to have 2 new turbos under warranty lol
don
Post by don » Sat Feb 02, 2008 1:34 am
that is funny two new turbos for nothing... what a bunch of gooses
don
Post by don » Sat Feb 02, 2008 1:38 am
nickelvery wrote:Mines got more oil than that, is there any way of telling if the piston rings are worn apart from removing the head?
Why don't you just take a spark plug out and do a compression test? You can get a compression gauge from an auto parts shop. If you squirt some oil in and the compression goes up then you know there's a prob with the rings though you might need to check the valve guides as well but getting a bit beyond my expertise now.
