got bored today...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
quattronutter
got bored today...
Post by quattronutter » Tue Jan 01, 2008 9:48 pm
engine fell out :shock:
quattronutter
ready for some fettling
Post by quattronutter » Tue Jan 01, 2008 9:50 pm
on the table
quattronutter
new s/h box
Post by quattronutter » Tue Jan 01, 2008 9:52 pm
spot the differences...pre facelift and facelift :?
spen
Post by spen » Tue Jan 01, 2008 11:02 pm
May I ask how many hours did that take? I think I'll be doing the same shortly.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
andybnwc
RE: new s/h box
Post by andybnwc » Tue Jan 01, 2008 11:03 pm
wish mine would fall out so i can check the turbos lol or someone pull it out cheap!!
spen
Post by spen » Tue Jan 01, 2008 11:04 pm
Er, is one mucky, the one with the oil feed?
quattronutter
Post by quattronutter » Tue Jan 01, 2008 11:08 pm
about 9 hours in all including getting the box off,i expect a lot more removing turbos,heads,sump,crank....came out easier than i expected
quattronutter
Post by quattronutter » Tue Jan 01, 2008 11:11 pm
spen wrote:Er, is one mucky, the one with the oil feed?
looked like an oil feed its actually a breather of some kind,centre diff is also slightly different and there is an extra hole next to the crank sensor at the bellhousing on the facelift[clean]box
quattronutter
Post by quattronutter » Tue Jan 01, 2008 11:13 pm
pre facelift has the extra hole i should say...was unused though
quattronutter
Re: RE: new s/h box
Post by quattronutter » Wed Jan 02, 2008 12:20 am
andybnwc wrote:wish mine would fall out so i can check the turbos lol or someone pull it out cheap!!
cheap doesnt equal a good job usually though
andybnwc
RE: Re: RE: new s/h box
Post by andybnwc » Wed Jan 02, 2008 12:27 am
i know thats the problem but with the engine out i can carry out all the work myself
quattronutter
Post by quattronutter » Wed Jan 02, 2008 12:39 am
engine comes out fairly easy if you dont rush it too much
andybnwc
Post by andybnwc » Wed Jan 02, 2008 2:35 pm
what special tools will i need to remove engine i have the bentley cd-rom workshop manual somewhere just cant find it
quattronutter
Post by quattronutter » Wed Jan 02, 2008 3:03 pm
extra large shoehorn....not really any special tools required came out quite easy compared to similar engines i have worked on,can do an engine swap on a 300zxtt in about 8 hours now after plenty of practise in the past,thats very similar layout to the audi,although the audi has about 2 million more vac pipes and wires
quattronutter
Post by quattronutter » Tue Jan 08, 2008 9:54 pm
got carried away,now turned into a complete engine rebuild,new rods pistons,bearings,flowed manifolds,bores honed ready for new pisons,there is virtually no bore wear at 160k
