Cheaper brake upgrade?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
travs
Post by travs » Thu Nov 29, 2007 2:26 pm
Correct me if I'm wrong but, on the basis that the Boxster S is both less powerful and lighter, the brakes probably wouldn't be that much of an upgrade.....
Written-off: Night Blue Metallic S6 5.2 V10 - Private plate, LED interior kit.
Sold:
Hibiscus Red Metallic S4 (B5 99.5) w/AmD Stage 1 Remap, RS4 Exhaust w/ Gutted Precats & R32 Tailpipes, Afterun Sensor, H&R Coilovers
Turbo Joe
Post by Turbo Joe » Thu Nov 29, 2007 3:20 pm
am8631 wrote:I have a further question for you experts out there. Can the calipers off a Boxster S be made to fit, what would be the cost involved? I can get a second hand set for only £300.
New parts are recommended everytime when it comes to those kind of parts sir, don't wanna be taking chances with second hand parts in that department.
SKN remap, K&N Filter, Miltek CatBack Twin Jet-
BHP under Construction!!!!
am8631
Post by am8631 » Thu Nov 29, 2007 3:25 pm
i would have to disagree with you there. Calipers are refurbished all the time - i would always use new discs and pads but there is nothing wrong with used calipers.
Turbo Joe
Post by Turbo Joe » Thu Nov 29, 2007 3:36 pm
Refurbishing calipers? Didn't even know this practice takes place. Well if you can get em cheap then by all means go for it.
JonnyX
Post by JonnyX » Thu Nov 29, 2007 3:52 pm
You need to measure the piston area and pad area and do some brake torque calculations. The stock
S4 calipers do have very good clamping force.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
GrimReaper
Post by GrimReaper » Thu Nov 29, 2007 4:13 pm
Stigter wrote:Is there any difference with the cayenne calipers (ie turbo s etc..)?
Not 100% if the caliper is different or just uses mounting bracket but Porsche do a 18" and 19" wheel version. Usually the 19" minimum wheel ones are red and the others are grey.
They probably could fit although may need mounting bracket to space them out then you'd have to consider what disc to use plus the disc offset. My Cayennes didn't cost me much more than that and they were 2nd hand but unused.
IMO if budget is your number one priority then go with the B5 RS4 set up else save up a bit more for B7 RS4 stuff or ECS stage 4 kits
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
hardhitter
Post by hardhitter » Sun Dec 02, 2007 1:48 pm
Do you need 18's for the RS4 B5 brakes, also what the difference between S4 and RS4 B5 rear brakes ?
MarkB
Post by MarkB » Sun Dec 02, 2007 2:03 pm
Yes you need 18" for the front. The RS4 rears are bigger also. Not sure if you need 18" for them though but probably do.
Mark
UKS4APR1
Post by UKS4APR1 » Mon Dec 03, 2007 12:21 am
MarkB wrote:Yes you need 18" for the front. The RS4 rears are bigger also. Not sure if you need 18" for them though but probably do.
RS4 Rears will fit under 17" Avus std. wheels. They are much larger dia. than S4.
Users browsing this forum: No registered users and 149 guests
