stage 1 remap question
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
JJmac
Post by JJmac » Wed Nov 28, 2007 12:55 pm
Cheers for the replies ,
plenty for me to think about - more that likely ill get the work done -
would be a shame not to see what it can really do.
Dippy
Post by Dippy » Wed Nov 28, 2007 1:38 pm
I thought Cosworth only worked on the RS4 version?
2001 Silver S4 Avant
hardhitter
Post by hardhitter » Wed Nov 28, 2007 2:03 pm
i thought that too...
ChipHazzard
Post by ChipHazzard » Wed Nov 28, 2007 2:47 pm
The 2.7T engine is an awesome bit of kit, totally over engineered by Audi/Cosworth
Audi designed it to start with then Cosworth fettled it later in lfe for the RS
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
MarkB
Post by MarkB » Wed Nov 28, 2007 3:23 pm
The only thing Cosworth did was improve the casting technique on the cylinder heads on the RS4. Urban myth says the designed the heads...
Mark
KayGee
Post by KayGee » Wed Nov 28, 2007 8:20 pm
Cosworth were more than consulted on the RS4 heads, they also made the heads and at least assembled the first years worth of RS4 engines (4,000). These were asembled in the UK, just down the road from me.
The RS4 heads are made using Cosworths patented casting technology at their Worcester forging facility.
The heads were machined in Hungary, sent back to the UK where the engines were assembled then sent to Germany for the cars to be assembled.
Cosworth Technology also worked with Audi on the RS4s brake system and specified the fueling components and turbocharger systems amongst other items.
This was the first time Audi publicly named Cosworth Technology as a technology partner, although the two companies had been working in conjunction on various projects in the past.
Now you know why the S4 engine is so good..... and why Audi bought Cosworth from Vickers.
Also why Mahle bought them from Audi....guess who makes the pistons used in the 1.8T, 2.7T?
Dippy
Post by Dippy » Thu Nov 29, 2007 1:44 pm
Exactly how much Cosworth did for the RS4 engine is totally irrelevant. This post is about the S4, and Cosworth had no involvement there.
Turbo Joe
Post by Turbo Joe » Thu Nov 29, 2007 3:28 pm
Can't beat a 2.7T.
SKN remap, K&N Filter, Miltek CatBack Twin Jet-
BHP under Construction!!!!
KayGee
Post by KayGee » Thu Nov 29, 2007 7:51 pm
Audis aluminium block V6 was designed and developed by Cosworth back in 95.
The same engine block that is used in the S4.
If it is an automotive aluminium casting and very high quality its pretty much a dead certainty Cosworth are responsible for it.
Turbo Joe
Post by Turbo Joe » Thu Nov 29, 2007 8:31 pm
Interesting info.
imolas4uk
Post by imolas4uk » Thu Nov 29, 2007 8:52 pm
i thought that the 2.7 t engine in the s4/rs4 had alloy heads,alloy sump and a cast iron block ?
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
S2tuner
Trader (Expired)
Post by S2tuner » Thu Nov 29, 2007 11:44 pm
KayGee wrote:Audis aluminium block V6 was designed and developed by Cosworth back in 95.
Sorry Kevin but the only alloy V6 block Audi have is the 3.0 30v, all 2.4 2.8 and 2.7s are cast iron. And I also stand by the other's statements about Cosworth's involvement in the RS4 engine development, and lack thereof in the S4 engine.
Mihnea
KayGee
Post by KayGee » Fri Nov 30, 2007 1:04 am
Sorry, you are correct it was the V6 cast iron block Cosworth did for Audi in 1995.
