Uprated rear diff mount - anyone interested in a GB??
Nige_RS4
Post by Nige_RS4 » Wed Nov 21, 2007 8:18 pm
This has just been released .... http://www.axismotorsport.com/shop/apik ... -p-74.html
Looks like a nice peice of kit - I wonder how it compares to a new OEM mount price-wise and it will fit both S4 & RS4 by the looks of things.
Post if you have the slightest interest in one of these - once I've got a rough idea of numbers I'll approach Axis to see what discount we can get.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Jarv
Post by Jarv » Wed Nov 21, 2007 8:24 pm
If it reduces clunkiness in the DT, then I'm interested, price dependant of course.
Mike
Q7
Peakz
Post by Peakz » Wed Nov 21, 2007 8:28 pm
What Jarv said.
MarkB
Post by MarkB » Wed Nov 21, 2007 8:29 pm
Are the standard ones a weak point then? Do they wear?
Mark
Nige_RS4
Post by Nige_RS4 » Wed Nov 21, 2007 8:34 pm
I believe so, that's what causes the clunking and drivetrain movement when you lift off the throttle or change gear!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
MarkB
Post by MarkB » Wed Nov 21, 2007 8:36 pm
Are there other options or is this the only uprated version out there?
Mark
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Nov 21, 2007 8:54 pm
the stock mounts are desinged to move a lot to stop the shock from diff play going through the car.
I think someone should try before you buy - the more rigid gearbox and engine mounts ruin comfort in the car.
http://www.MRCtuning.com
Nige_RS4
Post by Nige_RS4 » Wed Nov 21, 2007 8:58 pm
I agree 100% Doug - I wouldn't want any vibrations! I'll do some research on AW to see if anyones got them fitted yet.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Nige_RS4
Post by Nige_RS4 » Wed Nov 21, 2007 11:20 pm
Also available from these guys .... http://www.avalonmotorsports.com/index. ... cts_id=169 and was available in Oct at a discounted price of $219.
Trouble is, I have read a few reports of vibrations .... http://forums.audiworld.com/s4/msgs/2732783.phtml and here ... http://forums.audiworld.com/s4/msgs/2727234.phtml
Doesn't look very promising, even though they state they have tried it on 6 cars with no problems.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
JonnyX
Post by JonnyX » Thu Nov 22, 2007 4:16 pm
034 do this as well I think.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Golich
Post by Golich » Sun Jan 06, 2008 2:01 pm
I always meant to simply shim the gap in the rear mount before selling my B5. It would take approx 1hrs work to remove and shim the mount with some 3mm to 5mm thick small strips of flat bar or plate.
The mount/rubber is so soft it takes up the full slack by simply letting out the clutch. Given this I would be very surprised if vibration resulted. I have my old mount still in the garage. A new one made no difference to the clunk on changing gear. I'll see if Brooner is up for some experimentation.
Save your money and try the shim option first. I was going to simple screw the shims in place to see how it worked. If detrimental (highly unlikey) I would simply remove.
Have a look and you'll see for yourself what I'm talking about.
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jan 06, 2008 10:43 pm
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
tdiquattro
Post by tdiquattro » Wed Jan 09, 2008 6:27 pm
What about this on AW, .....
http://forums.audiworld.com/s4/msgs/2653216.phtml
worth a try to test it out?
Nige'
2000 silver S4 Saloon
JonnyX
Post by JonnyX » Wed Jan 09, 2008 6:51 pm
I'm up for this. There are also good reviews on the Apikol mount on AW. The bad review had some
other changes as well (snub mount).
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
S4TAN
Post by S4TAN » Wed Jan 09, 2008 6:55 pm
Yeah - I fancy a go on this - see what difference it makes. Isn't it worth trying the hockey puck version first .... or even the cut-up i/c hose shims?
Deus ex machina
