connected to vag-com using USB
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
r4fdud
Post by r4fdud » Sat Nov 17, 2007 3:48 pm
i have connected the VAG com using USB however it finds teh port but
keeps saying interface: not found!
can anyone tell me please teh possbilities of this problem please
TopBear
Post by TopBear » Sun Nov 18, 2007 11:47 pm
Have you installed the VAG-COM drivers, not just the VAG-COM program?
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
PetrolDave
Post by PetrolDave » Mon Nov 19, 2007 11:36 am
Have you connected the cable to the car AND turned the ignition on? The cable won't be found unless you have.
Sebastian
Post by Sebastian » Mon Nov 19, 2007 1:45 pm
Last but not least, only genuine Ross-Tech interface are compatible with the USB setting in VAG-COM. So if you are using a 3rd party interface you may want to check the instructions you got from the seller of your interface hardware. If in doubt state the name/type of your interface hardware and from whom your bought it.
Sebastian @ Ross-Tech.com
r4fdud
Post by r4fdud » Mon Nov 19, 2007 2:44 pm
i got teh cable from ebay from autonostics
Sebastian
Post by Sebastian » Mon Nov 19, 2007 5:18 pm
Under these circumstances your experience with the USB functionality of VAG-COM is totally correct. Your 3rd party interface does not provide a VAG-COM compatible direct USB access, it rather uses a virtual serial/com port which means as I said before you should refer to the instructions you got from the seller/vendor of your hardware or contact them for support that's your best bet.
r4fdud
Post by r4fdud » Mon Nov 19, 2007 5:39 pm
thanks for all the advise
Return to “DTC / VCDS”
