Fitting RS4 intercoolers?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
Post by h8cak » Wed Nov 07, 2007 12:51 am
I have just purchased a pair of rs4 ic's. I have the original rs4 pipe work and the original S4 pipes. My question is will either of these fit my s4 of will i need to get special pipes? and is there anything else i will need to get these on my S4?
Wide Body S4
Blue_Thunder
RE: Fitting RS4 intercoolers?
Post by Blue_Thunder » Wed Nov 07, 2007 12:57 am
Do you have an APR bi-pipe? If so, you'll need APR pipes to go from the coolers to the bi-pipe.
GrahamS4
Post by GrahamS4 » Wed Nov 07, 2007 7:46 am
And if not an APR bi-pipe? Can the RS4 pipes be utilised?
tdiquattro
Post by tdiquattro » Wed Nov 07, 2007 9:35 am
Which RS4 pipes are you talking about?, the ones below the sump from the turbos? or the alloy ones that go to the TB ?
If it is the lower ones then only the drivers side is different on the RS4, it is longer to bring the outlet closer to the intercooler, the passeger side is the same as the S4, they are all the same diameter 50mm.
all 4 RS4 Intercooler outlets/inlets are 63mm.
I have not seen the RS4 and S4 and APR bi-pipe together to see the difference in length but the inlet diameters are 57mm on the S4 and bi-pipe and 63mm on the RS4. (the Bi-pipe is a direct replacement for the S4 plastic pipes so is the same diameter).
You will need hoses to suit from the RS4 intercoolers, straight 63mm at the top hoses if you have the RS4 TB pipes. The lower ones will be step down 63mm to 50mm
RS4 hoses cannot be used although they are the right diameter they are too long as the intercoolers on the RS4 sit further out in the bumper.
hth , nigel.
Nige'
2000 silver S4 Saloon
h8cak
Post by h8cak » Wed Nov 07, 2007 11:15 am
so what do i need then? I dont have the bi pipe. Just the normal s4 pipe.
Wide Body S4
kies4
Post by kies4 » Wed Nov 07, 2007 11:35 am
I ran rs4 intercoolers with the standard s4 bi-pipe
nowI have the apr bi pipe, can't remember changing the rubber connectors
S4 Crazy Horse. Ringsticker & MRC black magic.
s4woody
Post by s4woody » Wed Nov 07, 2007 1:26 pm
your RS4 intercoolers will fit if you have the RS4 rubber intercooler pipes..BUT..you will need to use a very small piece of the S4 rubber intercooler pipes as a sleeve as the RS4 rubber intercooler pipes are bigger for the S4 inlet pipework..HTH
GARTH ROAD MOT CENTRE LTD
020 83353032
h8cak
Post by h8cak » Wed Nov 07, 2007 2:24 pm
yeah that does cheers si. Can i buy the brackets or do i need to make some up?
Wide Body S4
kies4
Post by kies4 » Wed Nov 07, 2007 3:31 pm
I don't have brackets at all, the pipes seem to keep in place, saying that i got some damage on one side from the knocking about.
s4woody
Post by s4woody » Wed Nov 07, 2007 4:12 pm
the driver side bracket dont fit cos of the air con canister..but you can fit the passenger side RS4 bracket ok..well drill out pop rivits and bolt it in place..otherwise like kies said the pipes will hold them in place..if you go that route then i,d atleast try and fit a small bracket to the side of the intercoolers to stop any undue vibrations..
020 83353032
Bosun20
Post by Bosun20 » Thu Nov 08, 2007 9:44 am
Go into this page www.audiworld.com/tech/eng.html and look in S4 section.This should help,It tells you a way of fitting them.
h8cak
Post by h8cak » Thu Nov 08, 2007 4:02 pm
Nice one. Very helpful
Wide Body S4
rolskii
Post by rolskii » Sat Nov 10, 2007 10:07 pm
s4woody wrote:the driver side bracket dont fit cos of the air con canister..
I got the can mounted as it was banging against my i/c, which is obviously causing a air flow restriction on the back side too ...
see if I can take some pics tomorrow as its in bits .... :lol:
happy dayz .... party ....
h8cak
Post by h8cak » Sun Nov 11, 2007 2:05 am
That would be good. Cheers Dude
Wide Body S4
rolskii
Post by rolskii » Sun Nov 11, 2007 11:30 pm
Heres some snaps, I used the original s4 can bracket to attach to the rs4 ic mounts, the captive stud in the old bracket is holding it to the upright arm(underneath) of the ic mount, its then had a bit of forming, used 2 of the ic jubilee clips, its nice an tight .... gives flow through the ic ... stops more rattles .. :audibash: HTH
Users browsing this forum: No registered users and 158 guests
