Sat Nav disc copy
tartan_rob
Sat Nav disc copy
Post by tartan_rob » Wed Oct 31, 2007 8:07 pm
If I was going to take a back-up copy of my 2007 sat nav disc (for example), what would I need to do it? apart from the obvious dual layer DVD writer?
Can it be done and if so what type of discs? I have tried DVD-R DL and they don't work.
2017 Kawasaki Z1000
2014 RS6
2014 S1
AlexJ
Post by AlexJ » Wed Oct 31, 2007 8:21 pm
I use DVD shrink to copy DVD's, not sure if it will work with a sat nav disc. You can download it free if you google it.
Might be worth a try!! :D
PetrolDave
Post by PetrolDave » Thu Nov 01, 2007 10:27 am
The EU sat nav disc has a weird copy protection scheme. You can only make copies with certain drives, certain software and certain media - there's some (very) long posts on www.navplus.us
Expect to make lots of coasters!
AlexJ
Post by AlexJ » Thu Nov 01, 2007 12:23 pm
I think DVD shrink gets past most copywrites, i've yet to encounter something it hasen't got past!!
Mind you there is always a first time..
duncanhancox
Post by duncanhancox » Thu Nov 01, 2007 1:17 pm
despite what people say, there is no copy protection
-the disk is larger than 4.5gb, and most copy software gets the layer break wrong so the disks dont work
-the reader is fussy and will often only read verbatim dvd+r dual layer disks or disks using the same media type
-you dont need to copy at 1x or 2x - i have tried verbatim upto 8x and it works fine as long as the media is rated at that speed
what you need is:
a copy of clonecd - to get the layer break write
a pioneer dual layer dvd writer - i've tested an a07, a08. dvd109 and 110 models all with success
verbatim 8.5gb dvd+r genuine media - dont waste your money on other stuff, it wont work properly
good luck
tartan_rob
Post by tartan_rob » Wed Nov 14, 2007 1:46 pm
Okay, I have the clone Cd software, my pioneer DVD writer and the verbatim dvd and nothing, it still fails. The DVD looks good, insert it and the sat nav unit says the disc is not comaptible with the audi sat nav.
Any ideas?
2017 Kawasaki Z1000
2014 RS6
2014 S1
ChipHazzard
Post by ChipHazzard » Wed Nov 14, 2007 1:57 pm
it might be worth giving dvd decrypter a go
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
duncanhancox
Post by duncanhancox » Wed Nov 14, 2007 2:05 pm
i tried about 12 different media types and any mkm 001 worked at 1x or 2.4x and any mkm 003 worked at 8x write without any problems at all
which pioneer writer are you using?
duncanhancox
did you use verbatim dvd-r? they dont work - only the dvd+r work
tartan_rob
Post by tartan_rob » Wed Nov 14, 2007 6:28 pm
Yep. DVD +r and pioneer 112d.
I can create the image with dvd decrypter but then I get an error when trying to write it, the actual copy button is disabled and the status bar says "Device not ready, Incompatible Medium installed".
I saved the image as ISO..
Any ideas? This is driving me mental.
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
Post by PetrolDave » Wed Nov 14, 2007 6:48 pm
Saw a post on www.navplus.us that says to copy the sat nav DVD you need a region free DVD writer (RPC1 firmware).
tartan_rob
Post by tartan_rob » Wed Nov 14, 2007 7:36 pm
The DVD writer is set to region free (or all regions), can't rememebr which.
rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “Electrical”
Users browsing this forum: No registered users and 165 guests
