Wheel Spacers
kaisersolsay
Wheel Spacers
Post by kaisersolsay » Sun Oct 28, 2007 6:32 pm
Hi guys,
Thinking about a set of wheel spacers to fill out the arches on my B6 S4. Anyone got any advise on which ones are best? Anyone got any pics?
Virdee Autos
Trader (Expired)
RE: Wheel Spacers
Post by Virdee Autos » Sun Oct 28, 2007 10:31 pm
I would use either H&R or Eibach myself
Both are excellent quality and H&R ones are TUV approved. And both AFAIK are hubcentric which is what you want
Virdee Autos ~ 07950-526592
kaisersolsay
RE: Wheel Spacers
Post by kaisersolsay » Mon Oct 29, 2007 1:17 pm
Thanks for that. You got any pics with them on?
Virdee Autos
Trader (Expired)
RE: Wheel Spacers
Post by Virdee Autos » Mon Oct 29, 2007 10:47 pm
There some pics in the RS4 B5 section, under "New wheels", but obviously they're on a RS4, plus on different wheels.
jvbates
Post by jvbates » Tue Oct 30, 2007 11:34 pm
I asked a similar thing in this thread, and got a reply from philipwalker, who said...
You could fit a hub center 10mm spacer, say Eibach or H+R . Generally any spacer less than 10mm does not have the center lip for the wheel to mount on.
It should not put any extra loading in the components, it would be the same a lower et number wider wheel.
Ring or PM me if you need a set.
Philip
01437 563793
He (by the looks of it?) runs or works for these guys...
http://tinyurl.com/2yxvgn
Hope that helps.
Jay
P_G
Re: RE: Wheel Spacers
Post by P_G » Wed Oct 31, 2007 12:24 pm
kaisersolsay wrote:Thanks for that. You got any pics with them on?
If you go to the TT Shop website IIRC they have pics of H&R hubcentric spacers on the hubs if that is what you are looking for. You will also need / get longer H&R TUV approved bolts if using H&R spacers.
MTM also supposedly do hubcentric spacers ITH.
Virdee Autos
Trader (Expired)
RE: Re: RE: Wheel Spacers
Post by Virdee Autos » Thu Nov 01, 2007 12:19 am
IMO your just paying the extra premium for the MTM badge!
They are more than likely made for them by either H&R or Eibach. Both AFAIK are TUV approved.
kaisersolsay
Post by kaisersolsay » Thu Nov 01, 2007 12:42 pm
What does TUV mean? :)
jvbates
Post by jvbates » Thu Nov 01, 2007 1:13 pm
TÜVs - Technischer Überwachungs-Verein, or Technical Monitoring Association in English!
It's the German motoring standards agency. See wikipedia
P_G
Re: RE: Re: RE: Wheel Spacers
Post by P_G » Thu Nov 01, 2007 1:48 pm
R33V-Spec wrote:IMO your just paying the extra premium for the MTM badge!
The MTM spacers actually have a bigger diameter and cover the entire face of the hub whereas H&R's there is a 5 mm lip round the circumference.
kaisersolsay
RE: Re: RE: Re: RE: Wheel Spacers
Post by kaisersolsay » Thu Nov 01, 2007 4:48 pm
What size would you recommend for a standard B6 S4? Don't want to foul the arches, but want to fill them out a bit.
P_G
Post by P_G » Thu Nov 01, 2007 5:12 pm
I had 10mm hubcentric spacers largely because of the RS4 front brake upgrade I had done to get the Avus wheels back on; however at the same time when looking straight down from above the wing the edge of the tyre and wheel were in line with the edge of the arch.
NotNormal
Post by NotNormal » Mon Nov 19, 2007 9:03 pm
P_G wrote:I had 10mm hubcentric spacers largely because of the RS4 front brake upgrade I had done to get the Avus wheels back on; however at the same time when looking straight down from above the wing the edge of the tyre and wheel were in line with the edge of the arch.
I have the same, 10 mm hubcentric H&R with matching bolt.
The whole car looks better, well worth doing IMO.
jvbates
Post by jvbates » Wed Nov 21, 2007 3:47 pm
I was reccomended by someone (and I can't find the post!) that 15mm at the rear and 10mm on the front was just about perfect!
MarkB
Post by MarkB » Wed Nov 21, 2007 4:22 pm
jvbates wrote:I was reccomended by someone (and I can't find the post!) that 15mm at the rear and 10mm on the front was just about perfect!
This post? http://www.rs246.com/index.php?name=PNp ... highlight=
Mark
Users browsing this forum: Majestic-12 [Bot] and 40 guests
