Mick Jagger lips on my rear brake discs (RS4)
TopBear
Post by TopBear » Mon Oct 08, 2007 11:21 pm
I've had a close look at my old discs that I took of last week, and am a bit concerned at what I think looks like an excessive inside and outside lip on those discs. The 2nd pic is even worse!!!
For those whom have changed discs\pads on a B5 RS4, does this look normal , or are the pads knacked?
One side
Other side
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
DavidT
RE: Mick Jagger lips on my rear brake discs (RS4)
Post by DavidT » Mon Oct 08, 2007 11:31 pm
What sort of use does the car get ? and did you put new pads on with the new discs?
MarkB
Post by MarkB » Tue Oct 09, 2007 8:30 am
I'd say the disc's look in a very poor state and I wouldn't use the pads that were bedded into this disc's on any new disc's.
Depending on the thickness of the lowest part of the disc you could get them refaced and used again with new pads, but as I say they must still be thick enough to be able to do that.
Mark
TopBear
Re: RE: Mick Jagger lips on my rear brake discs (RS4)
Post by TopBear » Tue Oct 09, 2007 9:57 am
DavidT wrote:What sort of use does the car get ? and did you put new pads on with the new discs?
The car gets used daily for 'brisk' commuting. I've never tracked it in the 14K miles I've used it. New pads were fitted around 10K miles ago when it had a major service, with advisory that new discs would be required soon.
I put the old pads back on, as they've still got what looks like 50%+ life left on all of them.
TopBear
Post by TopBear » Tue Oct 09, 2007 10:01 am
MarkB wrote:I'd say the disc's look in a very poor state and I wouldn't use the pads that were bedded into this disc's on any new disc's.
I'd agree :lol:
I have put the old pads back in, as I my thinking was that the pads would adapt to the new disc face.
The discs were skimmed and they are apparently down at the minimum thickness already, thats why I replaced them, but I did hang on to the hardly used pads.
I guess my concern was, is this sort of thick banding on the disc a normal characteristic of wear on rear discs on the RS4? Or if not, what is likely to cause?
MarkB
RE: Re: RE: Mick Jagger lips on my rear brake discs (RS4)
Post by MarkB » Tue Oct 09, 2007 10:07 am
With age the rust will creep in from both edges of the pad contact area.
I would recommend that you get new pads in ASAP as the old ones will have raised area's because of the rust on the old disks. This will mean the pads won't be fully in contact with the new disk and rust will start prematurely.
Mark
TopBear
Post by TopBear » Tue Oct 09, 2007 10:16 am
So in normal use the net effect should be that the pad covers the entire surface area and I shouldnt be seeing anything like these circles of rust?
MarkB
Post by MarkB » Tue Oct 09, 2007 10:27 am
Not straight away. You will see a look like that quite quickly if you leave the old pads in though. It's the pad that cleans the light rust off. Rust will eat the pads once it takes hold so the pads don't stand a chance
Mark
DavidT
Post by DavidT » Tue Oct 09, 2007 10:32 am
New discs and old pads = bad idea, especially with the state of those discs, as Mark says.
The B5 RS4 discs are expensive from memory but the pads are cheap ?
I asked what type of use they had had because it looks like an easy life, kept outside with short journeys ? this is the enemy of discs in terms of rust vs wear.
Old pads on new discs can be dangerous because of the way they heat up small parts of the disc surface - you do not have proper braking effort and it can take months (1000's of miles) for them to wear down.
Have you checked the calipers are working OK?
TopBear
Post by TopBear » Tue Oct 09, 2007 11:09 am
OK chaps, I shall get some new pads in there ASAP! Is there any recommendations other than the OEM ones?
s4woody
Post by s4woody » Tue Oct 09, 2007 12:51 pm
id say them discs are foooked ther topbear...the outside edge like markB said will eat the pads and make a terrible squeaking noise...
GARTH ROAD MOT CENTRE LTD
020 83353032
PhilT
RS246.com
Post by PhilT » Tue Oct 09, 2007 1:59 pm
I had a set that looked like that once. Obviously you should check the min thickness as your point of if they have any life left. In my case I got the grinder out and took off the lip, which was mainly rust.
yorkie
Post by yorkie » Tue Oct 09, 2007 6:29 pm
I would say time for new disks and pads mate.
TopBear
Post by TopBear » Tue Oct 09, 2007 8:41 pm
yorkie wrote:I would say time for new disks and pads mate.
The discs were replaced already, those are the old ones which came off the car.
MarkB
Post by MarkB » Tue Oct 09, 2007 8:50 pm
Just get some new pads on the new disc's so the new ones don't end up looking the same!
Mark
Users browsing this forum: No registered users and 39 guests
