For those whom have changed discs\pads on a B5 RS4, does this look normal , or are the pads knacked?
One side
Other side
The car gets used daily for 'brisk' commuting. I've never tracked it in the 14K miles I've used it. New pads were fitted around 10K miles ago when it had a major service, with advisory that new discs would be required soon.DavidT wrote:What sort of use does the car get ? and did you put new pads on with the new discs?
I'd agreeMarkB wrote:I'd say the disc's look in a very poor state and I wouldn't use the pads that were bedded into this disc's on any new disc's.
Depending on the thickness of the lowest part of the disc you could get them refaced and used again with new pads, but as I say they must still be thick enough to be able to do that.
