question about a noise on start up
rs6_newbie
Post by rs6_newbie » Fri Sep 21, 2007 3:38 pm
hi everyone
just in the process of purcahsing my 1st rs6 03 plate with 55k full audi service
when i have started the car from cold it sounds like a plane has just started its engines
after a couple of mins this noise goes away
is this normal or is there a problem
any help on the matter would be great also is there anythng else i should be looking out for which could be a problem
thanx inadvance
SteveH
RE: question about a noise on start up
Post by SteveH » Fri Sep 21, 2007 3:45 pm
No sounds normal to me... there's lots of jet wizardry under the bonnet when starting, whilst running and then after you've turned off.
Welcome to the big smiles club!
Present:...
Past:
Rupert
Post by Rupert » Fri Sep 21, 2007 4:10 pm
There are a few fans and pumps which start up, but I particularly like the switch-off whines, sounds like a plane has just stopped its engines ;)
tombs
Post by tombs » Fri Sep 21, 2007 4:20 pm
Yep, that is normal, fans pumps, and the warp engine kicking in :kissmyrings:
el_ringo
Post by el_ringo » Fri Sep 21, 2007 6:16 pm
Heh heh, I find the Air Con pump is the jet noise one. No idea why it is so loud on the '6
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
rs6_newbie
Post by rs6_newbie » Fri Sep 21, 2007 7:24 pm
thanx guys for the heads up! much appreciated!!!!javascript:emoticon(':D')
SteveH
Post by SteveH » Fri Sep 21, 2007 7:37 pm
I reckon that if you imagine the environment in which it operates, it needs to be a big bugger in the RS6 to overcome the heat from the beasts heart!
Present:...
Past:
justinthyme
Post by justinthyme » Sat Sep 22, 2007 5:22 am
speaking of fans and noise etc., are the turbo's in the rs6 self-lubricating? in other words, do you need to keep the car at idle for a couple of minutes before shutting down or can you kill it straight away (assuming normal / average driving) and how long should one allow it to cool down after a blast?
Rupert
Post by Rupert » Sat Sep 22, 2007 8:03 am
I always allow a cool-down time, but there is a secondary cooling circuit which keeps a pump working after switch-off.
CarlosV
Post by CarlosV » Mon Sep 24, 2007 8:50 am
I used to have a pump whirring away after switch off, but since I recently sent it in to get the doors to self lock whilst driving it seems to have disappeared. I put this down to me not driving hard enough on the short trip to work and back as its only about 5 miles I thought perhaps there was a temperature switch or something. But I was away for the weekend in the beast and noticed it still wasn't whirring after a longer trip, does anyone know if this after switch off cooling circuit is controlled/switched by the VAG codes or am I looking at something more expensive? It just seems a bit of a coincidence.
skiwi
Post by skiwi » Mon Sep 24, 2007 10:25 am
the "jet noise" is the 600watt (big) fan on primary speed for the air/con - turn that off and it will only start up when the engine temperature requires it.
the turbos have a water cooling circuit (in addition to the oil circuit) and an "after-run" pump which keeps the coolant circulating after switch off. you should *always* hear this going after switch off - a gentle wiring sound for a couple of minutes. it is triggered by engine temp >60c which will occur on even a 2 minute idle - which makes it easy to check.
nickband
Post by nickband » Mon Sep 24, 2007 3:04 pm
the air con fan makes a hell of a noise in my car
Users browsing this forum: Google [Bot], Shoppinit and 118 guests
