question about a noise on start up
rs6_newbie
hi everyone
just in the process of purcahsing my 1st rs6 03 plate with 55k full audi service
when i have started the car from cold it sounds like a plane has just started its engines
after a couple of mins this noise goes away
is this normal or is there a problem
any help on the matter would be great also is there anythng else i should be looking out for which could be a problem
thanx inadvance
thanx inadvance
RE: question about a noise on start up
No sounds normal to me... there's lots of jet wizardry under the bonnet when starting, whilst running and then after you've turned off.
Welcome to the big smiles club!
Present:...
Past:
Past:
There are a few fans and pumps which start up, but I particularly like the switch-off whines, sounds like a plane has just stopped its engines
Yep, that is normal, fans pumps, and the warp engine kicking in
Heh heh, I find the Air Con pump is the jet noise one. No idea why it is so loud on the '6
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Unit 20 TCU remap
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
Tesla Model X 60D
rs6_newbie
I reckon that if you imagine the environment in which it operates, it needs to be a big bugger in the RS6 to overcome the heat from the beasts heart!No idea why it is so loud on the '6
Present:...
Past:
Past:
justinthyme
speaking of fans and noise etc., are the turbo's in the rs6 self-lubricating? in other words, do you need to keep the car at idle for a couple of minutes before shutting down or can you kill it straight away (assuming normal / average driving) and how long should one allow it to cool down after a blast?
I used to have a pump whirring away after switch off, but since I recently sent it in to get the doors to self lock whilst driving it seems to have disappeared. I put this down to me not driving hard enough on the short trip to work and back as its only about 5 miles I thought perhaps there was a temperature switch or something. But I was away for the weekend in the beast and noticed it still wasn't whirring after a longer trip, does anyone know if this after switch off cooling circuit is controlled/switched by the VAG codes or am I looking at something more expensive? It just seems a bit of a coincidence.
the "jet noise" is the 600watt (big) fan on primary speed for the air/con - turn that off and it will only start up when the engine temperature requires it.
the turbos have a water cooling circuit (in addition to the oil circuit) and an "after-run" pump which keeps the coolant circulating after switch off. you should *always* hear this going after switch off - a gentle wiring sound for a couple of minutes. it is triggered by engine temp >60c which will occur on even a 2 minute idle - which makes it easy to check.
Users browsing this forum: Bing [Bot] and 116 guests
