where is egt measure block?(S4)
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
buzzard
Post by buzzard » Thu Aug 24, 2006 5:32 pm
as title
still concerns about sawing into sensors with dodgy manifold rattles
can i tell if sensor in question is damaged without removal of it?[/quote]
S2tuner
Trader (Expired)
RE: where is egt measure block?(S4)
Post by S2tuner » Thu Aug 24, 2006 11:21 pm
Hi,
If your ECU is the 8D0 907 551C part number, then there is no EGT measuring block. If it is an 8D0 907 551D, then it's block 112.
HTH,
Mihnea
flashyg
Post by flashyg » Wed Aug 30, 2006 12:41 am
what are the safe peaks of egt. Is momentary peaks of 980-1000 acceptable after heavy 4 gear pulls?
S2tuner
Trader (Expired)
Post by S2tuner » Wed Aug 30, 2006 12:49 am
By my standards, NO. Most cars that I tune very rarely exceed 945. 980 is accepted as tolerable by the factory but that is running factory boost levels/timing and fuelling (which has to pass very strict emissions).
buzzard
Post by buzzard » Wed Aug 30, 2006 10:05 am
ill check on part no and block 112
cheers Mihnea
got a feelin it is not on
had a span up the blocks last week and could not see it.
S4 B5 long gone
S4 B8 Stage 2
flashyg
Post by flashyg » Thu Aug 31, 2006 12:16 am
Thanks.
GrahamS4
Post by GrahamS4 » Sun Sep 23, 2007 2:03 pm
Hmm. I have the 8D0 907 551C so no EGT temp block on 112. Well it does come up EGT temp, but he value just looks like rpm to me.
I was going to log some before and after figures for an exhaust change. Is there anything else worth logging along the lines of EGT temp while I have the change beforehand?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 34 guests
