as title
still concerns about sawing into sensors with dodgy manifold rattles
can i tell if sensor in question is damaged without removal of it?[/quote]
where is egt measure block?(S4)
RE: where is egt measure block?(S4)
Hi,
If your ECU is the 8D0 907 551C part number, then there is no EGT measuring block. If it is an 8D0 907 551D, then it's block 112.
HTH,
Mihnea
HTH,
Mihnea
what are the safe peaks of egt. Is momentary peaks of 980-1000 acceptable after heavy 4 gear pulls?
By my standards, NO. Most cars that I tune very rarely exceed 945. 980 is accepted as tolerable by the factory but that is running factory boost levels/timing and fuelling (which has to pass very strict emissions).
ill check on part no and block 112
cheers Mihnea
got a feelin it is not on
had a span up the blocks last week and could not see it.
cheers Mihnea
S4 B5 long gone
S4 B8 Stage 2
S4 B8 Stage 2
Hmm. I have the 8D0 907 551C so no EGT temp block on 112. Well it does come up EGT temp, but he value just looks like rpm to me.
I was going to log some before and after figures for an exhaust change. Is there anything else worth logging along the lines of EGT temp while I have the change beforehand?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Users browsing this forum: Google Adsense [Bot] and 35 guests
