Painting Intercoolers
viperbl
Post by viperbl » Tue Sep 18, 2007 9:50 am
Guys,
I am looking to spray my silver FMIC black, as well as the pipes.
Although I am sure the pipes are not a worry, I don't want to affect the performance of the IC too much by spraying it ...
Any particular paints/sprays I should /should't use ???
RS4 B5 Saloon8) with 750+ bhp :D
MarkB
RE: Painting Intercoolers
Post by MarkB » Tue Sep 18, 2007 10:00 am
Black might even help the heat transfer? Just don't spray it on too thick on the cooling fins
Mark
viperbl
Re: RE: Painting Intercoolers
Post by viperbl » Tue Sep 18, 2007 10:12 am
MarkB wrote:Black might even help the heat transfer? Just don't spray it on too thick on the cooling fins
That would be good :)
My thinking was do the metal in between the fines with a slightly thicker coat (mask off the fins) and as you said, just do a very light coat on the fins (if even needed)
How hot does an IC get??? Do I need to check what temp the paint can go up to ???
MarkB
RE: Re: RE: Painting Intercoolers
Post by MarkB » Tue Sep 18, 2007 10:14 am
Don't MRC use something like B&Q BBQ paint on the pipes? Something that handles high heat would be advisable
Mark
viperbl
Post by viperbl » Tue Sep 18, 2007 10:18 am
I'm gonna give Doug a call this afternoon, I will ask him ... but makes sense to use something that can handle a little heat, its not manifold head, but still must/might get quite hot ...
DavidT
Post by DavidT » Tue Sep 18, 2007 10:27 am
I think Doug has painted his ?
viperbl
Post by viperbl » Tue Sep 18, 2007 10:53 am
Spoke to Doug, he uses hi temp paint from halfords ... matt black ... works fine. Pity we don't have a halfords out here!
Might just look for some hi temp paint and give it a go ... worst it can do is peel off I guess!
dummi
Post by dummi » Tue Sep 18, 2007 1:35 pm
excellent i was going to go black too
s4woody
Post by s4woody » Tue Sep 18, 2007 2:08 pm
but doesn't black absorb heat..surely silver or even white would reflect the heat and keep it cooler..or am i getting things asre about face...
GARTH ROAD MOT CENTRE LTD
020 83353032
GrahamS4
Post by GrahamS4 » Tue Sep 18, 2007 2:16 pm
I figure you would want them black internally and silver/white externally.
S4TAN
Post by S4TAN » Tue Sep 18, 2007 2:19 pm
I'd agree with that (if it was possible to do)
Deus ex machina
viperbl
Re: RE: Re: RE: Painting Intercoolers
Post by viperbl » Tue Sep 18, 2007 2:22 pm
GrahamS4 wrote:I figure you would want them black internally and silver/white externally.
Suppose that makes sense ...
But hopefully painting black on the outside will not make too much of a difference ....
S4TAN
RE: Re: RE: Re: RE: Painting Intercoolers
Post by S4TAN » Tue Sep 18, 2007 2:36 pm
Black objects absorb heat more readily than non-black objects (basic physics)... if you paint them on the outside then won't they simply become a hotter object for your charged air to pass through on it's way to your throttle body? Given the speed that the air passes through them though I'm not sure if it'll have much of an effect ... but then again they are meant to cool the air as it passes, so I'd've thought black would be the worse colour to paint your coolers if you're going to paint them at all ...
Deus ex machina
MarkB
Post by MarkB » Tue Sep 18, 2007 3:24 pm
but wouldn't the black paint absorb the heat from the metal drawing it to the surface to be transfered to the air
Mark
s4woody
Post by s4woody » Tue Sep 18, 2007 3:36 pm
isnt that what i said..mark i think tha the whole cooler would just be hotter..radiators in homes are white to radiate heat..if they were black would they work better or not..?
020 83353032
Users browsing this forum: Google Adsense [Bot] and 68 guests
