Painting Intercoolers
Guys,
I am looking to spray my silver FMIC black, as well as the pipes.
Although I am sure the pipes are not a worry, I don't want to affect the performance of the IC too much by spraying it ...
Any particular paints/sprays I should /should't use ???
RE: Painting Intercoolers
Black might even help the heat transfer? Just don't spray it on too thick on the cooling fins
Mark
Re: RE: Painting Intercoolers
That would be goodMarkB wrote:Black might even help the heat transfer? Just don't spray it on too thick on the cooling fins
My thinking was do the metal in between the fines with a slightly thicker coat (mask off the fins) and as you said, just do a very light coat on the fins (if even needed)
How hot does an IC get??? Do I need to check what temp the paint can go up to ???
RE: Re: RE: Painting Intercoolers
Don't MRC use something like B&Q BBQ paint on the pipes? Something that handles high heat would be advisable
Mark
I'm gonna give Doug a call this afternoon, I will ask him ... but makes sense to use something that can handle a little heat, its not manifold head, but still must/might get quite hot ...
I think Doug has painted his ?
Spoke to Doug, he uses hi temp paint from halfords ... matt black ... works fine. Pity we don't have a halfords out here!
Might just look for some hi temp paint and give it a go ... worst it can do is peel off I guess!
excellent i was going to go black too
but doesn't black absorb heat..surely silver or even white would reflect the heat and keep it cooler..or am i getting things asre about face...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I figure you would want them black internally and silver/white externally.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
I'd agree with that (if it was possible to do)I figure you would want them black internally and silver/white externally.
Deus ex machina
Re: RE: Re: RE: Painting Intercoolers
Suppose that makes sense ...GrahamS4 wrote:I figure you would want them black internally and silver/white externally.
But hopefully painting black on the outside will not make too much of a difference ....
RE: Re: RE: Re: RE: Painting Intercoolers
Black objects absorb heat more readily than non-black objects (basic physics)... if you paint them on the outside then won't they simply become a hotter object for your charged air to pass through on it's way to your throttle body? Given the speed that the air passes through them though I'm not sure if it'll have much of an effect ... but then again they are meant to cool the air as it passes, so I'd've thought black would be the worse colour to paint your coolers if you're going to paint them at all ...But hopefully painting black on the outside will not make too much of a difference ....
Deus ex machina
but wouldn't the black paint absorb the heat from the metal drawing it to the surface to be transfered to the air
Mark
isnt that what i said..mark i think tha the whole cooler would just be hotter..radiators in homes are white to radiate heat..if they were black would they work better or not..?
020 83353032
020 83353032
