Flashing LED on the door lock pins
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
AdamS4
Post by AdamS4 » Tue Sep 18, 2007 10:26 am
Since i played around with the alarm codes (Trying to get the remote boot release working)... The flashing LED lights on the door lock pins don't flash anymore.
What should be the correct code for that ??
MarkB
Re: Flashing LED on the door lock pins
Post by MarkB » Tue Sep 18, 2007 11:12 am
AdamS4 wrote: (Trying to get the remote boot release working)...
Can't help with the door lock leds but when trying to open the boot you did hold the button in didn't you? Needs to be held for a couple of seconds then the boot pops open
Mark
AdamS4
Post by AdamS4 » Tue Sep 18, 2007 11:24 am
Oh, no... i didn't know that :oops: Thanks :)
neily
Post by neily » Tue Sep 18, 2007 11:28 am
double check that all doors and tailgate are defintiely closed as I have noticed that unless all doors are firmly shut the LED's will not function (even though the central locking may work). You may have 'popped' the tailgate in error ?
2001 RS4 Avant - thats been touched by the MRC magic wand.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008
Dippy
Post by Dippy » Tue Sep 18, 2007 1:43 pm
Agreed. I have never come across a way of configuring the central locking to not flash the LEDs, but I have many times noticed that my LEDs are not flashing only to find out that a door is slightly open.
2001 Silver S4 Avant
shineydave
Post by shineydave » Tue Sep 18, 2007 9:37 pm
indeed that's true but you can do some very strange things by coding a module incorrectly, i managed to swap the functions of the remote buttons when i added up the options wrong
Dave
AdamS4
Post by AdamS4 » Wed Sep 19, 2007 12:46 pm
Well, the boot release is working... Did what Mark said... hold it down and it popped open... woohoo
Still gotta sort this LED thing now... Could it be cause i've removed the alarm horn ??
Sebastian
Post by Sebastian » Fri Sep 21, 2007 6:15 pm
What exactly did you do/change?
Sebastian @ Ross-Tech.com
Return to “DTC / VCDS”
