message as follows: Excessive comms error.. By the way the Airbag light is on in the dashboard.
Any ideas ????
Airbag Controller 15
RE: Airbag Controller 15
What car?
Not sure if it is that exact code that gets thrown, but on the B5 it is common for the connection under the seat to cause the airbag light. Remove, clean, refit an clear the code and see if it stays away. Or just rest and see if it stays awa like mine has.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Uwe@Ross-Tech
- 1st Gear
Is communications stable with the other systems in your car (Engine, ABS, Instruments, etc?). I.e. is the airbag module the only one that gives you problems, or are you having issues with all the systems in the car?
Here's a bunch of things to look at:
http://www.ross-tech.com/vag-com/faq_2.html#2.5
-Uwe-
-Uwe-
