Much better
t_urbo
Post by t_urbo » Fri Sep 14, 2007 7:23 am
DoctorD wrote:There is no risk of damage, its only an exhaust. What is really surprising about the RS4, is that with them disconnected (i.e. valves remain fully open at all times) the car drives much more smoothly and progressively, gives better MPG and doesn't sound much louder (certainly from within the cabin). It just sounds more characterful and fun.
That's what's really daft about it, with valves disconnected it feels a much better all-round car - with no downsides whatsoever.
p.s. EVO's long termer used a standard exhaust, and now my car behaves 'exactly' as it did. I'm really glad I chanced upon this discovery.
It there was a difference in MPG then it must be so small i can't see how you could ever carry out a test accurate enough to tell.
t_urbo
Post by t_urbo » Fri Sep 14, 2007 7:30 am
Mori wrote:I don't believe that opening the flaps at mid-rpm ranges will affect AFR enough to make a difference. Not with the stock exhaust. Any pros willing to venture more conclusive evidence?
There is a 10Nm difference in power when the flaps open so there must be a shift in the Air/Fuel Ratio.
Mori
Post by Mori » Fri Sep 14, 2007 8:06 am
How do you know this? Any dyno sheets to prove that t_urbo? Just asking because I have not heard of anything of the sort.
audijohn
Post by audijohn » Fri Sep 14, 2007 8:25 am
I am very interested in the "Improved fuel consumption" figure you got, just what in terms of miles per gallon benifits have seen?.
DoctorD
Post by DoctorD » Fri Sep 14, 2007 8:26 am
The difference in MPG has nothing to do with any change in the engine, but 'everything' to do with how you therefafter drive it. If the torque is more accesible, then smaller throttle openings will achieve the same end result.
DoctorD
Post by DoctorD » Fri Sep 14, 2007 8:29 am
audijohn wrote: I am very interested in the "Improved fuel consumption" figure you got, just what in terms of miles per gallon benifits have seen?.
More consistently above 20mpg than below (before I was getting more like 18-19mpg)
audijohn
Post by audijohn » Fri Sep 14, 2007 8:31 am
OK thanks. It would seem then "Bottom end/ slow " running is better with improved breathing, this is pure guess work.
DoctorD
Post by DoctorD » Fri Sep 14, 2007 8:39 am
Yes, precisely. It just feels like the engine has been 'released' and is now able to operate as intended, whereas it was really uneven and stifled before. The S5 I had also felt free to breath (at the bottom end), which is why I started exploring ways of achieving similar with the RS4.
audijohn
Post by audijohn » Fri Sep 14, 2007 8:41 am
DoctorD wrote:
audijohn wrote:
DoctorD wrote: More consistently above 20mpg than below (before I was getting more like 18-19mpg)
I will give this a try later today, run it for a week and see what happens, :beerchug:
ChrisRS4
Post by ChrisRS4 » Fri Sep 14, 2007 10:33 am
I did mine last night, and I'd have to agree with DoctorD. The engine definitely feels like it flows better at low rpm and the noise is much better :)
audijohn
Post by audijohn » Fri Sep 14, 2007 10:42 am
ChrisRS4 wrote:I did mine last night, and I'd have to agree with DoctorD. The engine definitely feels like it flows better at low rpm and the noise is much better :)
Nice one Chris. 8)
ChuckUK
Post by ChuckUK » Fri Sep 14, 2007 10:54 am
Wow this is such an interesting subject.
Is there any way you can get 100% power when you want it? VAGCom change etc or would it require a remap? Why would they reduce the power to 50-60% in gears 1-3 below 5.5k? does version 80 of the software solve this as some folks are saying the surge at 5.5k has gone?
DoctorD
Post by DoctorD » Fri Sep 14, 2007 11:06 am
I am assuming mine has version 80 of the s/ware since its a brand new car and it still felt like it was restrained in those first few gears. Now it doesn't.
This adjustment really is a no-brainer IMO, I cannot see why anyone would not do it since it doesn't make the car feel any less civilised, but adds back a bucketload of character and smoothness that was being hidden.
It's really quite a bizzarre difference from 'only' opening up the exhaust valves, I would have predicted from past experience that it would only improve the noise.
Scoobysnack
Post by Scoobysnack » Fri Sep 14, 2007 12:12 pm
If I can on Sat i will ask the dyno guys to use a sniffer or AFR meter on my car to see what the ratio is on flap and open flap....... will really try to get this done on sat using all gears.
Anyone else already done that?
J
Mori
Post by Mori » Fri Sep 14, 2007 12:41 pm
Waiting for some data. :)
Users browsing this forum: No registered users and 166 guests
