It there was a difference in MPG then it must be so small i can't see how you could ever carry out a test accurate enough to tell.DoctorD wrote:There is no risk of damage, its only an exhaust. What is really surprising about the RS4, is that with them disconnected (i.e. valves remain fully open at all times) the car drives much more smoothly and progressively, gives better MPG and doesn't sound much louder (certainly from within the cabin). It just sounds more characterful and fun.
That's what's really daft about it, with valves disconnected it feels a much better all-round car - with no downsides whatsoever.
p.s. EVO's long termer used a standard exhaust, and now my car behaves 'exactly' as it did. I'm really glad I chanced upon this discovery.
Much better
I am very interested in the "Improved fuel consumption" figure you got, just what in terms of miles per gallon benifits have seen?.DoctorD wrote:There is no risk of damage, its only an exhaust. What is really surprising about the RS4, is that with them disconnected (i.e. valves remain fully open at all times) the car drives much more smoothly and progressively, gives better MPG and doesn't sound much louder (certainly from within the cabin). It just sounds more characterful and fun.
The difference in MPG has nothing to do with any change in the engine, but 'everything' to do with how you therefafter drive it. If the torque is more accesible, then smaller throttle openings will achieve the same end result.t_urbo wrote:
OK thanks. It would seem then "Bottom end/ slow " running is better with improved breathing, this is pure guess work.DoctorD wrote:More consistently above 20mpg than below (before I was getting more like 18-19mpg)audijohn wrote: I am very interested in the "Improved fuel consumption" figure you got, just what in terms of miles per gallon benifits have seen?.
Yes, precisely. It just feels like the engine has been 'released' and is now able to operate as intended, whereas it was really uneven and stifled before. The S5 I had also felt free to breath (at the bottom end), which is why I started exploring ways of achieving similar with the RS4.audijohn wrote:OK thanks. It would seem then "Bottom end/ slow " running is better with improved breathing, this is pure guess work.DoctorD wrote:More consistently above 20mpg than below (before I was getting more like 18-19mpg)audijohn wrote: I am very interested in the "Improved fuel consumption" figure you got, just what in terms of miles per gallon benifits have seen?.
I will give this a try later today, run it for a week and see what happens,DoctorD wrote:Yes, precisely. It just feels like the engine has been 'released' and is now able to operate as intended, whereas it was really uneven and stifled before. The S5 I had also felt free to breath (at the bottom end), which is why I started exploring ways of achieving similar with the RS4.audijohn wrote:OK thanks. It would seem then "Bottom end/ slow " running is better with improved breathing, this is pure guess work.DoctorD wrote: More consistently above 20mpg than below (before I was getting more like 18-19mpg)
Wow this is such an interesting subject.
Is there any way you can get 100% power when you want it? VAGCom change etc or would it require a remap? Why would they reduce the power to 50-60% in gears 1-3 below 5.5k? does version 80 of the software solve this as some folks are saying the surge at 5.5k has gone?
I am assuming mine has version 80 of the s/ware since its a brand new car and it still felt like it was restrained in those first few gears. Now it doesn't.
This adjustment really is a no-brainer IMO, I cannot see why anyone would not do it since it doesn't make the car feel any less civilised, but adds back a bucketload of character and smoothness that was being hidden.
It's really quite a bizzarre difference from 'only' opening up the exhaust valves, I would have predicted from past experience that it would only improve the noise.
- Scoobysnack
- 1st Gear
Users browsing this forum: Bing [Bot] and 1410 guests
