Disabling the valve in the active exhaust . . .
Mori
Post by Mori » Thu Sep 13, 2007 4:34 pm
CJD245: do you screw the screw in or just push it in?
CJD245
Post by CJD245 » Thu Sep 13, 2007 4:41 pm
Mori wrote:CJD245: do you screw the screw in or just push it in?
Turn it in with fingers and then just nip-it up for the last few threads with a screw-driver!
JWB7V8
Post by JWB7V8 » Thu Sep 13, 2007 6:21 pm
I thought the software upgrade from version 50 to 80 meant that the valves now stay open in sport mode all of the time i.e. including when the revs are low?? :?:
John
2006 Sprint Blue RS4 + Milltek + APS Remap
t_urbo
Post by t_urbo » Thu Sep 13, 2007 6:34 pm
sunshine wrote:But Milltek offer a non-valved cat-back system do they not? Would this not present the same problem if any existed with the valves open all the time?
Rather than remove the pipes and plug them and the valves, would it not be possible to just clamp the pipes shut in situ - which can be readily reversed if an issue arises?
That's right and at the DMS group buy the car with the Miltek was running leaner than it should, not that it was proven to be the cause but common sense should tell you that changing the exhaust or over-riding the flaps is going to have an effect on the AFR's and without the proper map may cause the engine to run leaner.
It's possible that doing so may cause the ECU to pull the timing and result in LESS power, albeit small.
t_urbo
Post by t_urbo » Thu Sep 13, 2007 6:35 pm
JWB7V8 wrote:I thought the software upgrade from version 50 to 80 meant that the valves now stay open in sport mode all of the time i.e. including when the revs are low?? :?:
No
audijohn
Post by audijohn » Fri Sep 14, 2007 8:06 am
I mailed a mate Will @ http://www.p-torque.co.uk/
about "running issues with this "Flap bypass", he has confirmed that this mod does NOT cause problems. :)
Mori
Post by Mori » Fri Sep 14, 2007 8:07 am
Just for the sake of everyone on here, would you consider pasting in the whole email - as in your question + his answer?
audijohn
Post by audijohn » Fri Sep 14, 2007 8:20 am
Mori wrote:Just for the sake of everyone on here, would you consider pasting in the whole email - as in your question + his answer?
I can't as it was on "Tyresmoke" and as users know your mails are not kept only replies.
The jist was:
If the Flaps in the back boxs are over ridden manually and kept open, will this have a lean fuel running issue with the engine, or an long term engine problems.
His reply was:
"The Flaps can be bypassed with NO funning issues"
audijohn
Post by audijohn » Fri Sep 14, 2007 8:21 am
The jist was:
His reply was:
"The Flaps can be bypassed with NO running issues"
Mori
Post by Mori » Fri Sep 14, 2007 11:01 am
Thanks!
audijohn
Post by audijohn » Fri Sep 14, 2007 8:34 pm
GlynRS2
Post by GlynRS2 » Sat Sep 15, 2007 6:30 pm
Have disabled the valves just as described by CJD245 and yes it only takes about 10mins tops.
It seems to have cured a slight hesitation there was in the mid-rev range - certainly worth doing and dead easy to reverse the mod if ever you felt the need. :thumb:
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
Ozrs4
Post by Ozrs4 » Mon Sep 17, 2007 4:08 am
Here are some photos I posted over rs6.com board showing the screws used to plug the ends. Regards.
http://www.rs6.com/forum/showthread.php?t=13080&page=2
2007 RS4 B7 - Phantom black saloon
Users browsing this forum: Google [Bot] and 341 guests
